Message 1 of 1
ilogic to create envelope of a part(s) in an assembly
I am trying to develop a tool that, after opening a STEP file from any CAD vendor and Inventor convert it to an IAM, will allow the user to pick the parts in the assembly that have too much detail and create a simplified envelope (box or cylinder) in place of the selected parts. I am also doing this in 2022. I have found a couple of rules here that do some of what I need and I have put them together in the code below. It does not do the cylinder yet, but the main issue is that when I go to do the shrinkwrap in the code, it does not include the envelopes. These will be going into an AutoCAD toolset so I need the envelopes to show up as solids and not as assembly features. Any help would be great.
Sub Main()
Dim oDoc As AssemblyDocument = ThisDoc.Document
CreateBoxEnvelope()
'CreateEnvelope()
CreateBIM(oDoc, False)
End Sub
Public Sub CreateBIM(oDoc As AssemblyDocument, Optional ForcePreviewImage As Boolean = False)
Dim BaseFileName As String
BaseFileName = Left(oDoc.FullFileName, Len(oDoc.FullFileName) -4)
Dim oPartDoc As PartDocument
oPartDoc = ThisApplication.Documents.Add(kPartDocumentObject, , ForcePreviewImage)
'shrinkwrap definition
Dim oSWD As ShrinkwrapDefinition
oSWD = oPartDoc.ComponentDefinition.ReferenceComponents.ShrinkwrapComponents.CreateDefinition(oDoc.FullDocumentName)
Dim oCol As ObjectCollection
oCol = ThisApplication.TransientObjects.CreateObjectCollection
Dim oOccu As ComponentOccurrence
For Each oOccu In oDoc.ComponentDefinition.Occurrences
oCol.Add(oOccu)
Next
oSWD.AdditionalIncludedOccurrences = oCol
'Set Shrinkwrap Options
oSWD.RemoveInternalParts = True
oSWD.DeriveStyle = kDeriveAsSingleBodyNoSeams
oSWD.UseColorOverrideFromSourceComponent = True
oSWD.RemoveHolesStyle = kShrinkwrapRemoveByRange
oSWD.RemoveHolesDiameterRange = 6
oSWD.BreakLink = True
Dim oSWComp As ShrinkwrapComponent
oSWComp = oPartDoc.ComponentDefinition.ReferenceComponents.ShrinkwrapComponents.Add(oSWD)
Dim strSubstituteFileName As String
Dim num = 1
strSubstituteFileName = BaseFileName & "_Shrinkwrap" & num & ".ipt"
While IO.File.Exists(strSubstituteFileName)
Logger.Trace("Shrinkwrap file exists, increasing number")
num = num + 1
If num > 50 Then
Exit While
End While
oPartDoc.SaveAs(strSubstituteFileName, False)
'Properties
Dim Description As String
Dim PartNumber As String
Dim ComponentType As String
Dim Manufacturer As String
Dim Model As String
Dim URL As String
'Set properties
Description = "Skid"
PartNumber = iProperties.Value("Project", "Part Number")
Manufacturer = "ENTER MANUFACTURER"
Model = Right(BaseFileName, 6)
URL = ""
'Release reference to Assembly Doc
oDoc = Nothing
'Set Component Type
ComponentType = "23.75.50.17.31" ' Skid
Dim invPartNoProperty As Object
Dim invDescProperty As Object
invPartNoProperty = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Part Number")
invDescProperty = oPartDoc.PropertySets.Item("Design Tracking Properties").Item("Description")
invPartNoProperty.Value = PartNumber
invDescProperty.Value = Description
'Get Reference BIM Component
Dim oBIM As BIMComponent
oBIM = oPartDoc.ComponentDefinition.BIMComponent
'Write Component Type Definition
'If this line isn't run, the Model Properties tickbox will not get ticked and Model Properties will not get exported
oBIM.ComponentDescription.ComponentType = ComponentType
'Get reference for writing Identity Data
Dim oBimOC As BIMComponentPropertySet
oBimOC = oBIM.ComponentDescription.ComponentPropertySets.Item("Identity Data")
'Write BIM Identity data
'This must be set after 'Write Component Type Definition' otherwise this data will get wiped
Dim BIMDescProp As BIMComponentProperty
Dim BIMManProp As BIMComponentProperty
Dim BIMModelProp As BIMComponentProperty
Dim BIMURLProp As BIMComponentProperty
BIMDescProp = oBimOC.Item(1)
BIMDescProp.Value = Description
BIMManProp = oBimOC.Item(2)
BIMManProp.Value = Manufacturer
BIMModelProp = oBimOC.Item(3)
BIMModelProp.Value = Model
BIMURLProp = oBimOC.Item(4)
BIMURLProp.Value = URL
'Export .adsk file
Dim BIMExport = oPartDoc.File
Dim ExportFileName = Left(oPartDoc.FullFileName, Len(oPartDoc.FullFileName) -4)
ExportFileName = ExportFileName & ".adsk"
Dim Location = InputBox("Where would you like to Export To/as:" & vbLf & "Note: file name to be included with extension .adsk", "PLANT-BIM", ExportFileName)
oBIM.ExportBuildingComponent(Location)
'Close the invisibly opened part document.
'If this document isn't closed or unreferenced, a retry of the code will fail.
oPartDoc.Close(False)
oPartDoc = Nothing
End Sub
Sub CreateBoxEnvelope()
Dim oSelected As ObjectCollection
Dim oSelect As Object
oSelected = ThisApplication.TransientObjects.CreateObjectCollection
While True
oSelect = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAssemblyOccurrenceFilter, "Select a component for BOX envelope")
If IsNothing(oSelect) Then Exit While
oSelected.Add(oSelect)
End While
For Each oSelect In oSelected
Dim Occ As ComponentOccurrence
If oSelected.Count >= 1 Then
For i = 1 To oSelected.Count
Occ = oSelected.Item(i)
Try
oDoc = ThisApplication.ActiveDocument
Dim oCompDef As AssemblyComponentDefinition
oCompDef = oDoc.ComponentDefinition
Dim oClientFeatures As ClientFeatures
oClientFeatures = oCompDef.Features.ClientFeatures
oOccu = Occ 'ThisApplication.CommandManager.Pick(kAssemblyOccurrenceFilter, "Select an occurrence in assembly")
Dim oRangeBox As Box
oRangeBox = oOccu.RangeBox
If oRangeBox.MinPoint.DistanceTo(oRangeBox.MaxPoint) > 0.000001 Then
Dim oTransientBrep As TransientBRep
oTransientBrep = ThisApplication.TransientBRep
Dim oEnvelopeBody As SurfaceBody
oEnvelopeBody = oTransientBrep.CreateSolidBlock(oRangeBox)
Dim oClientFeaDef As ClientFeatureDefinition
oClientFeaDef = oClientFeatures.CreateDefinition("Envelope")
Dim oClientFea As ClientFeature
oClientFea = oClientFeatures.Add(oClientFeaDef, "MyEnvelope")
oClientFeaDef = oClientFea.Definition
Dim oClientGraphics As ClientGraphics
oClientGraphics = oClientFeaDef.ClientGraphicsCollection.Add("Envelope")
Dim oGraphicsNode As GraphicsNode
oGraphicsNode = oClientGraphics.AddNode(oClientGraphics.Count + 1)
Call oGraphicsNode.AddSurfaceGraphics(oEnvelopeBody)
oOccu.Visible = False
oDoc.Update
Catch
End Try
Next
Next
End Sub
** If my reply resolves this issue, please choose Accept Solution **
Scott Hallmark, Design Specialist | Fluor Corporation
Inventor and AutoCAD Certified Professional, Autodesk Certified Instructor | My Plant3D Notes | AU Speaker | ROLL TIDE!
