Ilogic: What is type of PropertySet.Item?
j.pavlicek
j.pavlicek
what is type of PropertySet.Item? It has to be Property (according the API Help).
But when I use following code, it gives me error The keyword is not a type. (Translated to EN by me.)
Dim iProps As PropertySet
Dim iProp As Property  'Error here
Why?
(I used Object instead of Property.)
Inventor 2022, Windows 10 Pro
Sorry for bad English.
marcin_otręba
try:
Dim iProp As [Property]
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
j.pavlicek
Could you please provide some sauce? What square brackets around a type means?
Thank you!
marcin_otręba
with google uncle:
"The square brackets is used so that the compiler interprets it as a type, even if it would be a keyword."
j.pavlicek
Thank you, my Google is returns nonsence.
