- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Dear All,
Currently im working with assemblys with a lot of different configurations (excel driven). The visibility of specific pats are controlled bye true/false user parameters. I'm looking for a rule/code to change the BOM Structure of all invisible parts to Reference and the structure of all visible parts to Default.
I've achieved to change the BOM structure for each part with a seperate line of code:
If OZP = 1 Then
Component.Visible("B200001:6") = True
Component.InventorComponent("B200001:6").BOMStructure = BOMStructureEnum.kDefaultBOMStructure
Else
Component.Visible("B200001:6") = False
Component.InventorComponent("B200001:6").BOMStructure = BOMStructureEnum.kReferenceBOMStructure
End If
But I would like to apply a global rule that read the whole document and change the BOM structure of each invisible/visible part in the assembly.
I know LoD can achieve this easy, but I just want to avoid using them. They give me to much trouble in this project.
Does somebody have any ideas suggestions??
Many thanks up front
