iLogic/VBA - Pack & Go with options
amarcoc
Message 1 of 9
amarcoc
Hi.
Any iLogic or VBA to create a pack and go with some predefined options?
I need to be able to have options in attached image selected. Thanks!
Replies (8)
Message 2 of 9
tobias.orlow
Hi Marco,
Find here Pack and Go VB sample code from the API help documentation with the settings you marked:
Public Sub PackAndGoSample()
    Dim oPacknGoComp As New PackAndGoLib.PackAndGoComponent
    Dim oPacknGo As PackAndGoLib.PackAndGo
    oPacknGo = oPacknGoComp.CreatePackAndGo("C:\Temp\Source\Assembly1.iam", "C:\Temp\Destination")
    ' Set the design project. This defaults to the current active project.
    oPacknGo.ProjectFile = "C:\Temp\Source\Test.ipj"
    Dim sRefFiles = New String() {}
    Dim sMissFiles = New Object
    ' Set the options
    oPacknGo.IsSkippingLibraries = false
    oPacknGo.IsSkippingStyles = True
    oPacknGo.IsSkippingTemplates = True
    oPacknGo.IsCollectingWorkgroups = False
    oPacknGo.IsKeepingFolderHierarchy = True
    oPacknGo.IncludeLinkedFiles = True
    ' Get the referenced files
    oPacknGo.SearchForReferencedFiles(sRefFiles, sMissFiles)
    ' Add the referenced files for package
    oPacknGo.AddFilesToPackage (sRefFiles)
    ' Start the pack and go to create the package
    oPacknGo.CreatePackage()
End Sub
Tobias Orlow
Designated Support Specialist
Customer Success Organization
Linkedin: www.linkedin.com/in/tobiasorlow/
Message 3 of 9
amarcoc
Thanks!
That's VB.net? I dont know how to use it. I am using VBA and iLogic.
Any VBA Method available? Check attachment picture
Message 4 of 9
JhoelForshav
Hi @amarcoc
Try this example as an iLogic rule 🙂
AddReference "Autodesk.PackAndGo.Interop.dll"
Dim oPacknGoComp As New PackAndGoLib.PackAndGoComponent Dim oPacknGo As PackAndGoLib.PackAndGo oPacknGo = oPacknGoComp.CreatePackAndGo(ThisApplication.ActiveEditDocument.FullFileName, "C:\DESTINATIONFOLDERPATH") 'Your destination folder Dim sRefFiles = New String() {} Dim sMissFiles = New Object oPacknGo.SkipLibraries = True oPacknGo.SkipStyles = True oPacknGo.SkipTemplates = True oPacknGo.CollectWorkgroups = False oPacknGo.KeepFolderHierarchy = True oPacknGo.IncludeLinkedFiles = True oPacknGo.SearchForReferencedFiles(sRefFiles, sMissFiles) oPacknGo.AddFilesToPackage(sRefFiles) oPacknGo.CreatePackage()
Message 5 of 9
amarcoc
That is almost perfect! Thanks.
EDIT: Added ZIP folder at the end. Here is my full code:
AddReference "System.IO.Compression"
AddReference "System.IO.Compression.FileSystem"
Dim oFolder As String = ThisDoc.Path & "\PDF Automaticos\PG_" & DateTime.Now.ToString("yyyy.MM.dd_HH.mm.ss")' & "\"
Try
	MkDir(oFolder)
	Catch
End Try
oPacknGo = oPacknGoComp.CreatePackAndGo(ThisApplication.ActiveEditDocument.FullFileName, oFolder) 'Your destination folder
oPacknGo.SkipLibraries = False
System.IO.Compression.ZipFile.CreateFromDirectory(oFolder, oFolder & ".zip")
Message 6 of 9
amarcoc
Updated code:
- Added filetype check
- Added ZIP
- Delete P&G folder
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
	MessageBox.Show("Apenas pode executar esta macro num ficheiro *.iam", "Erro!")
	Return
End If
Try
	MkDir(oFolder)
	Catch
End Try
Dim oCommand As String = CStr("cmd.exe /c rmdir /s /q " & """" & oFolder & "\""")
Dim oShellCommand As Object = CreateObject("WScript.Shell")
oShellCommand.Run (oCommand)
Message 7 of 9
amarcoc
I'm back.
The previous code does not execute the usual "search now" on large assembly. What could be wrong?
Message 8 of 9
ILU
hallo
did anyone find a solution to PackAndGo ilogic rule for big assemblies ?
Message 9 of 9
sam
Hi @JhoelForshav, Any idea why it misses references assemblies and parts?
Zipped folder got only the document where we run this code.
regards,
sam
