[iLogic] Updating iProperty "Creation Date" to current date in all components of assembly
michal.lachawiec
michal.lachawiec
I just created little script to update creation time (or other) iProperty of all parts within assembly to current date.
I hope it will be useful for someone
It is simple script and tbh first one that is working šŸ™‚ , if you have any comments how to improve it I will gladly read them.
Dim oDoc As Document
' Define the document
Dim oAssy As Document = ThisApplication.ActiveDocument
Dim allDocs As DocumentsEnumerator = oAssy.AllReferencedDocuments
'Try to update assembly date
Try
oAssy.PropertySets.Item(3).Item(1).Value() = Date.Today.AddDays(0)
Catch
End Try
For Each oDoc In allDocs
	Dim oPropSets As PropertySets = oDoc.PropertySets
    Dim oDesTrackProps As PropertySet = oPropSets.Item(3)
'Try to update part date
	Try
	oDesTrackProps.Item(1).Value() = Date.Today.AddDays(0)
	Catch
	End Try
Next
JelteDeJong
There is a software development principle "Don't repeat yourself" (DRY). Your code does not compile with this principle. You wrote the code to update the property twice (WET-code šŸ˜‰ It is good practice to factor that out to a new function.
Also, you used the item numbers for the PropertySet and the Property. Those numbers are not guaranteed to be always the same. (Maybe the order changes depending on the languae of Inventor or the Inventor version.) I think it's better to use the names. (All names can be found here.)
The last thing I think you can improve is not using "ThisApplication.ActiveDocument" but "ThisDoc.Document". Most of the time you will get the same object but not in all cases. The active document is not always what you expect. In this post, you find some rule that makes use of this difference maybe you find this example useful.
Anyway this is how I would write this rule:
Public Sub Main()
	Dim doc As Document = ThisDoc.Document
	UpdateCreationDate(doc)
	For Each refDoc In doc.AllReferencedDocuments
		UpdateCreationDate(refDoc)
	Next
End Sub
Private Sub UpdateCreationDate(doc As Document)
	Try
		Dim propSets As PropertySets = doc.PropertySets
		Dim desTrackProps As PropertySet = propSets.Item("Design Tracking Properties")
		Dim propCreatinTime As [Property] = desTrackProps.Item("Creation Time")
		propCreatinTime.Value() = Date.Today
	Catch ex As Exception
		MsgBox("Could not update 'Creation Time' in document: " & doc.DisplayName)
	End Try
End Sub
Jelte de Jong
Blog: hjalte.nl - github.com
will.astill
Just thought I'd post a little thank you to you both. I'm trying really hard to learn some iLogic and having this kind of forum post is really useful for me and is appreciated.
Special thanks also for the link to mod the machine.  You've earned your like šŸ™‚
