iLogic trim centerline at countour option
yvandelafontaine
yvandelafontaine
Hello all,
When I export a flat pattern there is the option to trim centerline at countour:
When using the ilogic export option i cannot seem to find the option argument needed to put it a "True"
EX: sOut = "FLAT PATTERN DXF?AcadVersion=2000&RebaseGeometry=True&SimplifySplines=False&TrimCenterlineAtContour=True&OuterProfileLayer....
Anybody figured this one out yet?
sajith_subramanian
Autodesk Support
Autodesk Support
Hi yvandelafontaine,
Unfortunately, that option is currently not available through the API.
Sajith
Sajith Subramanian
Autodesk Developer Network
Raider_71
Dear Autodesk. Can you please add this option into the API. This option has been added to Inventor 2015 or 2016 and the API was never updated to cater for this. PLEASE add it as its not complete.
Thank you!
yvandelafontaine
Raider_71
That is fantastic news thank you!
Just one question. How to use it...?
Would this work?
or
TrimCenterlinesAtContour=True
I cannot find any info in the API help...
Thanks again!
Raider_71
Ok for anyone else looking for an answer.
I presume this fix came in 2019 update 1. The correct string to use is: "&TrimCenterlinesAtContour=True"
Cheers
