Ilogic to use part of filename to populate iProperty
aurel_e
aurel_e
Hi all,
I need to add to all the components (parts and subassies) of an assembly an iproperty that is an extract of the filename
I tried the code below but is working just for the parts not the subassies.
Sub Main
	On Error Resume Next
	Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim oAsmDef As AssemblyComponentDefinition = oAsmDoc.ComponentDefinition
	Dim oLeafOccs As ComponentOccurrencesEnumerator = oAsmDef.Occurrences.AllLeafOccurrences
	'when you turn this on, you should also turn it back off when done
	ThisApplication.SilentOperation = True
	Dim oOcc As ComponentOccurrence
	For Each oOcc In oLeafOccs
		iProperties.Value(oOcc.Name, "Custom", "PN5") =(Mid(oOcc.Name, 11, 3))
	Next
End Sub
FINET_Laurent
Hello @aurel_e,
The issue you are facing is that the AllLeafOccurrences collection contains each single part of the assembly.
To perform the desired task, you will need a recursive function that will go through each occurrences, & sub-occurences if present, thus englobing also the assemblies. Here a code with no error handling :
Sub Main
	Dim doc As AssemblyDocument = ThisApplication.ActiveDocument
	Dim acd As AssemblyComponentDefinition = doc.ComponentDefinition
	addProperty(acd.Occurrences)
End Sub
Sub addProperty(occs As Inventor.ComponentOccurrences) 'recursive
	For Each occ As Inventor.ComponentOccurrence In occs
		iProperties.Value(occ.Name, "Custom", "PN5") = (Mid(occ.Name, 11, 3))
		If occ.SubOccurrences.Count > 0 Then addProperty(occ.SubOccurrences)
	Next
End Sub
Kind regards,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
aurel_e
Perfect. I had to add that
  on the 2nd part of the code to make it work.
Many thanks.
