Ilogic to turn all the parts in default representation to visible
naveedmX3N25
Message 1 of 20
naveedmX3N25
I am new to ilogic and have started to learn creating external rules to help my work flow.
I am currently looking for some help with the code to turn on all parts visible for the default representation. See below:
Replies (19)
Message 2 of 20
Frederick_Law
You picked something that look easy but in fact pretty complicated.
The "All Hidden" command depends on selection, in this case "Default" in View Rep.
To select "Default" you need to get the "Browser Pane".  Find "Representations" then "View" then "Default".
Select "Default" then execute "All Hidden".
Which require to find "Internal command name" of "All Hidden".
There is more detective work then coding 🤣
I was trying to sort "Titleblock", "Sketch Symbol" in drawing.
Using "Event Watcher" from SDK the command is:
"AssemblyAllInvisibleDesignViewCmd"
and
"AssemblyAllVisibleDesignViewCmd"
Message 3 of 20
naveedmX3N25
@Frederick_Law  -
Thanks for the reply.
Got it.
I thought it was something easy. Also I wanted all Visible not all Hidden. Mistake on my side on the question.
Do you know of an easier way to code make all parts visible in an assembly not taking this route?
Thanks.
Message 4 of 20
Frederick_Law
I'm almost there:
Got it:
ThisApplication.ActiveDocument.BrowserPanes.ActivePane.TopNode.BrowserNodes.Item("Representations").BrowserNodes.Item(1).BrowserNodes.Item("Default").DoSelect
ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyAllVisibleDesignViewCmd").Execute
Can't use name to get "View" because the label depends on view activated.
Actually might need to activate "Default" before setting "All Visible".
Message 5 of 20
naveedmX3N25
Thank you!!! Works Great!
Message 6 of 20
Frederick_Law
Do need to "Activate" and "Select" it again.
ThisApplication.ActiveDocument.BrowserPanes.ActivePane.TopNode.BrowserNodes.Item("Representations").BrowserNodes.Item(1).BrowserNodes.Item("Default").DoSelect 'Representation
ThisApplication.CommandManager.ControlDefinitions.Item("ActivateDesignViewCmd").Execute
Message 7 of 20
naveedmX3N25
I was thinking the same thing.
Thanks again!!!
Message 8 of 20
A.Acheson
Hi @naveedmX3N25
This is also possible with the inventor API which would be the preferred method over using commands.
Dim occs As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
Dim asmDef As AssemblyComponentDefinition = ThisDoc.Document.ComponentDefinition
For Each leafOcc In asmDef.Occurrences.AllLeafOccurrences
    occs.add(leafOcc)
Next
Dim designViewRep As DesignViewRepresentation = asmDef.RepresentationsManager.DesignViewRepresentations.Item("Default")
designViewRep.SetVisibilityOfOccurrences(occs, True)
Regards
Alan
Message 9 of 20
naveedmX3N25
Thank you. This also works but you have to have default selected.
Message 10 of 20
A.Acheson
To select just use activate see help page here
Syntax
DesignViewRepresentation.Activate()
designViewRep.Activate
Updated code
    occs.add(leafOcc)
Next
Regards
Alan
Message 11 of 20
naveedmX3N25
Hello Acheson,
One of the issue I have with code it for some reason when all the parts are visible it doesn't seem to be visible completely what I mean is when I hover over the part it doesn't select the part, only shows a box around the part. But when I manually turn OFF the visibility and turn it ON it works fine.
I am not sure how to fix the code.
Message 12 of 20
naveedmX3N25
@Frederick_Law
I have been using this code for some time. Thanks to you. But I of the issue I constantly get is I have to get the representations expanded to show default for this code to work sometimes it works without expanding it and sometimes I have to manually expand it.
Before the code can we add anything that would expand the representations --> View so that this code works all the time.
Appreciate the help.
Message 13 of 20
A.Acheson
Hi @naveedmX3N25
Do you have a screenshot of what your seeing? Is the part visible or not visible? Maybe there is an update needed.
Regards
Alan
Message 14 of 20
Frederick_Law
Check if there is "Default" view first.
Original IV template come with "Primary" only.
Might need to create "Default".
I added "Default" and "Design" to my Templates.
Message 15 of 20
naveedmX3N25
Same here. All of my templates have Default.
I was able to find a solution that works all the time.
Posting it below.
Message 16 of 20
naveedmX3N25
I have attached the screenshot of what I see when I click on the part.
I have able to solve this with the code I have posted below.
Message 17 of 20
naveedmX3N25
@A.Acheson @Frederick_Law - Below is the code that works all the time. Might help someone looking to do the same.
Sub Main()
    Dim doc As AssemblyDocument = ThisApplication.ActiveDocument
    Dim compDef As ComponentDefinition = doc.ComponentDefinition
    ' Iterate through all components in the assembly
    For Each compOccurrence As ComponentOccurrence In compDef.Occurrences
        compOccurrence.Visible = True
    Next
End Sub
Message 18 of 20
Frederick_Law
I got it now.
Added a line to expand the node before Activate.
ThisApplication.ActiveDocument.BrowserPanes.ActivePane.TopNode.BrowserNodes.Item("Representations").BrowserNodes.Item(1).BrowserNodes.Item("Default").Expanded = True
Message 19 of 20
A.Acheson
Hi @naveedmX3N25
Glad to see your getting some solutions working.
Interesting why you needed to set each occurrence visible separately. That is the purpose of "designViewRep.SetVisibilityOfOccurrences" once you supply the occurrence collection to the design view rep and select true they are all set to visible. It is working in my test so there must be something in your workflow stopping it from working. Are you using model states? I am only using primary state in 2022.
Regards
Alan
Message 20 of 20
naveedmX3N25
Not I am not using model states. Mine is also set to Primary State in inventor 2023.
