iLogic to select by iLogic
mohandis2
mohandis2
looking to detect if a view is selected, I think I used IsSelected in VBA with Autocad or Excel before,
but it does not exist in inventor iLogic,
please help.
For Each oView In oSheet.DrawingViews
     If oView.IsSelected=true then .......
next
JamieVJohnson2
This will work:
  Public Sub DoWorkOnView()
        Dim invApp as Inventor.Application = ThisApplication
        If invApp IsNot Nothing Then
            If invApp.ActiveDocumentType = DocumentTypeEnum.kDrawingDocumentObject Then
                Dim invDoc As Inventor.DrawingDocument = invApp.ActiveDocument
                Dim trans As Inventor.Transaction = invApp.TransactionManager.StartTransaction(invDoc, "DoWorkOnView")
                If invDoc.SelectSet.Count = 0 Then MsgBox("Please select the view first.")
                For Each item As Object In invDoc.SelectSet
                    If TypeOf item Is Inventor.DrawingView Then
                        Dim dv As DrawingView = item
                         'verify this is the view you want to use, and do your work on it.
                    End If
                Next
                trans.End()
            End If
        End If
    End Sub
Instead of asking each view object, we cycle through the document selection set.
Jamie Johnson : Owner / Sisu Lissom, LLC https://sisulissom.com/
mohandis2
thank you, this is a VBA routin
JamieVJohnson2
you should be able to 'shoe horn' it into your VBA, just change all the:
dim object as type = instance
to two lines:
dim object as type
set object = instance
