Ilogic to save assy and subassembly/parts
Nate.KurthUYTF3
Nate.KurthUYTF3
I have an assembly that uses parts and subassemblies. All the parameters are run from a form and all that works great. What I need is to adjust the main assembly file and then save that file as (BeamClamp-"BeamSize"). That "BeamSize" is a drop down text parameter in the assembly that drives everything.
I also need to save the updated versions of the subassemblies and parts in the top assembly with that same naming convention.
The goal is to have a bunch of new assemblies specific to beam sizes and I want to use ilogic to do the drawings on these as well so that is all done in a standard format.
Jakub.Szymanik
If you have a finite number of combinations you can generate all the possibilities from excel (also drawings) based on this video:
iLogic - automatyzacja tworzenia typoszeregów
Unfortunately, it is in Polish, so if you need further help with this solution I will be happy to help.
