ilogic to insert row into excel
Hi Guys,
 Is it possible to use iLogic to insert a row into excel? and if so could you PLEASE enlighten me the Code?
Many ThanksSmiley Happy
xiaodong_liang
Autodesk Support
Autodesk Support
iLogic does not wrap everything as functions. But it is based on .NET. So you can use Excel API as you did with .NET. And it is a pure question of using Excel API. Here is a post which looks good for youto get started with:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/How-to-create-a-excel-file-using-ilogi...
