How to get details of a constraint from a list of Assembly constraints? C++
oransen
oransen
Given the list of AssemblyConstraints how do I list them textually? For example
// error checking removed for brevity
CComPtr<AssemblyConstraints> pConstraintList;
pAssDef->get_Constraints(&pConstraintList) ;
_tprintf_s (_T("The assembly has %d constraints\n"),pConstraintList->Count);
const int ikNum = pConstraintList->Count ;
for (int iConstraint = 0 ; iConstraint < ikNum ; i++) {
    CComPtr<AssemblyConstraint> pConstraint;
    hr = pConstraintList->... what to put here?
    ... how to print out more data here...?
How do I get each constraint from the list? And if there is some example of printing out the data that would be good too. I'd need a C++ solution...
oransen
I've managed to get halfway there:
    const int ikNumConstraints = pConstraintList->Count ;
    for (int j = 1 ; j <= ikNumConstraints ; j++) {
        hRes = pConstraintList->get_Item(CComVariant(j),&pConstraint) ;
        if (FAILED(hRes)) {
            _tprintf_s (_T("Could not get the constraint %d of the assembly, hr=%X\n"),j,hRes);
            return ;
        _tprintf_s (_T("Got constraint %d\n"),j);
        // details????
but how to get textual descriptions of the contraints?
adam.nagy
Autodesk Support
Autodesk Support
Different constraints have different properties. So once you have the specific constraint then you can collect the information from them. E.g.:
  HRESULT hRes;
  CComQIPtr<AssemblyDocument> pDoc = pInvApp->ActiveDocument;
  CComPtr<AssemblyConstraints> pConstraintList = pDoc->ComponentDefinition->Constraints;
      CComPtr pConstraint;
      if (FAILED(hRes)) {
          return NOERROR;
      _tprintf_s (_T("Got constraint %d\n"), j);
      _tprintf_s (_T("Name = %s\n"), (LPCTSTR)pConstraint->Name);
      CComQIPtr<MateConstraint> pMate = pConstraint;
      if (pMate != NULL)
        // print info
      CComQIPtr<AngleConstraint> pAngle = pConstraint;
      if (pAngle != NULL)
        // print info
         _tprintf_s (_T("Angle = %s\n"), (LPCTSTR)pAngle->Angle->Expression);
I hope this helps.
Cheers,
Adam Nagy
Autodesk Platform Services
oransen
Ah, thanks. Easy when you know how!
