iLogic to fix iCopy defaults
HogueOne
Message 1 of 1
HogueOne
Hey there! Thanks for checking out my post.
I'm currently learning iLogic to try to increase Automation for my company's workflow. I've attached a document that basically outlines where we see this going. There's also a picture that demonstrates the sheet metal panels we manufacture. The reason I'm writing the code is because it takes too much time to manually rename all objects in the iCopy process. So I want to accept the default names and save locations and reorganize the references into a single folder.
I hope to write a code that will accomplish the following:
  • Prompt the user to select a target folder
  • Prompt the user to input a project number
  • Prompt the user to input a panel group ID
  • Generate a sequential suffix
  • Iterate through each occurrence
  • For each occurrence, if the occurrence is an assembly...
    • Combine the project number, panel group, a string, and the suffix to create a new part number
    • Update the part number
    • Update the occurrence name
    • Copy the file to the target folder
    • Rename the copied file to match the part number
    • Component replace the referenced file with the copied file in the target folder
    • Iterate through each subcomponent and search for components containing a certain string.
    • For each component containing the string:
      • Update the sub-occurrence name
      • rename the copied file to match the part number
    • Repeat the process for a component containing a different string.
Eventually I will need to figure out how to reassociate the drawing files with the new copied references. But I have no idea how. An alternative would be to use iLogic to make new drawing files for each occurrence in the assembly, but I'm still not sure how to do that.
Below is a snippet of how far I got with Chat GPT. It got me part of the way through my goal but trying to add new functions was unsuccessful no matter what I tried. I'm willing to bet there's a more efficient way to approach this than what Chat GPT came up with. Would anyone be kind enough to spare some time to help me?
Sub Main()
    ' Prompt user to select a folder
    Dim folderDialog As Object
    folderDialog = CreateObject("Shell.Application").BrowseForFolder(0, "Select a folder", 0, 0)
    If folderDialog Is Nothing Then
        MsgBox( "No folder selected. Exiting script.", vbExclamation, "No Folder Selected")
        Exit Sub
    Dim selectedFolder As String
    selectedFolder = folderDialog.Self.Path
    ' Prompt user for project number
    Dim projectNumber As String
    projectNumber = UCase(InputBox("Enter project number:", "Project Number Input"))
    ' Prompt user for panel group
    Dim panelGroup As String
    panelGroup = UCase(InputBox("Enter panel group:", "Panel Group Input"))
    ' Get the active assembly document
    Dim asmDoc As AssemblyDocument
    asmDoc = ThisApplication.ActiveDocument
    Dim asmCompDef As AssemblyComponentDefinition
    asmCompDef = asmDoc.ComponentDefinition
    Dim occurrences As ComponentOccurrences
    occurrences = asmCompDef.Occurrences
    Dim count As Integer
    count = 1
    Dim updatedAssemblyCount As Integer
    updatedAssemblyCount = 0 ' Counter to track updated assemblies
    Dim foundSubassembly As Boolean
    foundSubassembly = False ' Flag to track if any subassemblies were found
    ' Iterate through each occurrence
    For Each occurrence As ComponentOccurrence In occurrences
        If occurrence.DefinitionDocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then
            ' Get the subassembly document
            Dim subassemblyDoc As AssemblyDocument
            subassemblyDoc = occurrence.Definition.Document
            ' Generate sequential suffix
            Dim suffix As String
            suffix = count.ToString("000")
            count = count + 1
            ' Combine project number, panel group, and suffix to create new part number
            Dim newPartNumber As String
            newPartNumber = projectNumber & "-" & panelGroup & "-PANEL-" & suffix
            ' Update display name
            occurrence.Name = newPartNumber
            ' Update part number property
            iProperties.Value(occurrence.Name, "Project", "Part Number") = newPartNumber
            ' Check and rename specific parts within the subassembly
            For Each subOcc As ComponentOccurrence In subassemblyDoc.ComponentDefinition.Occurrences
                If subOcc.DefinitionDocumentType = DocumentTypeEnum.kPartDocumentObject Then
                    Dim partName As String
                    partName = UCase(subOcc.Name) ' Convert to uppercase for case-insensitive comparison
                    ' Check if part name contains 'LP' or 'ACM' (case insensitive) and rename accordingly
                    If partName Like "*LP*" Then
                        Dim newSubPartNumber As String
                        newSubPartNumber = projectNumber & "-" & panelGroup & "-LP-" & suffix
                        subOcc.Name = newSubPartNumber
                        iProperties.Value(subOcc.Name, "Project", "Part Number") = newSubPartNumber ' Update part number property
                        ' Rename and copy the file
                        RenameAndCopyFile( subOcc, newSubPartNumber, selectedFolder)
                    ElseIf partName Like "*ACM*" Then
                        newSubPartNumber = projectNumber & "-" & panelGroup & "-ACM-" & suffix
            Next
            updatedAssemblyCount = updatedAssemblyCount + 1 ' Increment count of updated assemblies
            foundSubassembly = True ' Set flag to true since we found at least one subassembly
    Next
    ' Show message if no subassemblies were found
    If Not foundSubassembly Then
        MsgBox( "No subassemblies or occurrences were found in the assembly.", vbExclamation, "No Components Found")
    Else
        ' Display message with count of updated assemblies
        MsgBox( updatedAssemblyCount & " components updated.", vbInformation, "Update Complete")
End Sub
' Function to rename and copy the part file to the selected folder
Sub RenameAndCopyFile(occurrence As ComponentOccurrence, newPartNumber As String, folderPath As String)
    On Error Resume Next ' Error handling
    Dim partDoc As Document
    partDoc = occurrence.Definition.Document
    Dim partFilePath As String
    partFilePath = partDoc.FullFileName
    Dim fso As Object
    fso = CreateObject("Scripting.FileSystemObject")
    ' Get the current file path and filename
    Dim currentFilePath As String
    currentFilePath = partDoc.FullFileName
    Dim currentFileName As String
    currentFileName = fso.GetFileName(currentFilePath)
    ' Get the new file path in the target folder
    Dim newFileName As String
    newFileName = newPartNumber & "." & fso.GetExtensionName(currentFileName)
    Dim newFilePath As String
    newFilePath = fso.BuildPath(folderPath, newFileName)
    ' Copy the file to the selected target folder if not already there
    If Not fso.FileExists(newFilePath) Then
        fso.CopyFile( currentFilePath, newFilePath, True)
    ' Rename the file in the target folder (if needed)
    If fso.FileExists(newFilePath) Then
        fso.MoveFile( newFilePath, fso.BuildPath(folderPath, newFileName))
    ' Clean up
    fso = Nothing
End Sub
Replies (0)
