bodies not recognized as surfacebody
Michele_DeLucaSW7PJ
Message 1 of 8
Michele_DeLucaSW7PJ
Hi everyone
i'm trying to do some work on these bodies in this attached part but ilogic does not see them
ComponentDefinition.SurfaceBodies.Count
has 0 as result ..how is it possible?
Replies (7)
Message 2 of 8
WCrihfield
That's interesting, and very odd.  It is showing two bodies in the model browser tree, under the Solid Bodies folder, but is oddly not showing any 'proper'/native features below the Origin folder.  Just a couple icons that look like the body icons, with names like "None" & "None_1", for some reason.  And I too get zero bodies from the following code within that part:
Dim oPDoc As PartDocument = ThisDoc.Document
MsgBox("Bodies Count = " & oPDoc.ComponentDefinition.SurfaceBodies.Count.ToString,,"")
How was this part created?  Is it imported from some other file type?  Did it get some other part(s) derived into it, but the 'Link' was broken to its/their source?  Please explain.
Wesley Crihfield
(Not an Autodesk Employee)
Message 3 of 8
Michele_DeLucaSW7PJ
Hi yes i think some kind of weird import..
i notice that is recognized as feature..
ComponentDefinition.Features.Count
 the result of this is 2
the problem is that i need to get the maximum length dimension thru OrientedMinimumRangeBox but this works only for solid bodies..
Message 4 of 8
WCrihfield
You can use the same Function from the ComponentDefinition object.
Dim oOBox As OrientedBox = oPDoc.ComponentDefinition.OrientedMinimumRangeBox
Wesley Crihfield
Message 5 of 8
Michele_DeLucaSW7PJ
yes that will work
thank you!
Message 6 of 8
Stakin
the basic reason is the component need to repair the surfacebody or surface. I guess
an error occurred during the  translating.
Message 7 of 8
Michele_DeLucaSW7PJ
yes in fact I imported again and they are recognized as bodies..
Message 8 of 8
Stakin
Congratulation,It is solved!
