iLogic to export PDF to mimic file structure
To_Efficiency_and_Beyond
To preface this request, I would like to say that we don't currently have vault. We will eventually get vault, but it will take quite a while. This will save a huge amount of time in the interim.
I have already successfully created a rule that:
1. updates the active drawing in various ways
2. saves
3. creates a pdf in the same location as the drawing file
4. closes the drawing
I am very happy with this progress, but if I am able to go a step further, it would same a ton of time for future workflows.  Here is my goal:
The drawing is saved in a project folder, and will be 1 to 5 sub-folders deep
(ex1. Example Project Folder 123\02 Sector 1\03 Frame\01 Frame Plates\Frame Plate 01.dwg)
(ex2. Example Project Folder 456\01 GA\GENERAL ARRANGEMENT.dwg)
I want the PDF saved in a different folder structure that mimics where the drawing is located.
I would like the rule to backtrack up the file structure until it finds a folder called "$Fabrication Data" and then navigate to or create the required sub-folders to mimic the original location. The PDF save location would be as follows:
(ex1. Example Project Folder 123\$Fabrication Data\02 Sector 1\03 Frame\01 Frame Plates\Frame Plate 01.pdf)
(ex2. Example Project Folder 456\$Fabrication Data\01 GA\GENERAL ARRANGEMENT.pdf)
Ralf_Krieg
Hello
You can try this function.
Private Function GetPath(oDrawDoc As DrawingDocument) As String
Dim sFullDocumentPath As String = IO.Path.GetDirectoryName(oDrawDoc.FullDocumentName)
Dim aPathParts() As String = Strings.Split(sFullDocumentPath, "\")
For i=0 To UBound(aPathParts)
	sNewPath = snewpath & aPathparts(i) & "\"
	If IO.Directory.Exists(sNewPath & "\$Fabrication Data") Then
		sNewPath=sNewPath & "$Fabrication Data\"
	End If
Next
Return snewpath
End Function
Call it from your sub via
Dim MyDrawDoc as DrawingDocument=ThisDoc.Document
Dim mySavePath as String = GetPath(myDrawDoc)
AFAIK the save methods to export a PDF creates all folders that are missing in the given save path (if you have proper rights).
R. Krieg
RKW Solutions
www.rkw-solutions.com
For some reason I can't get this to work. I tried running just the piece you supplied and put in a line to display the sNewPath value in a message box, no message box would appear. No error is displayed when the code is run, but it seems to prevent itself from finishing.
Ralf_Krieg
Hello
Tested it again and for me it worked. I wrote it in a little test rule with soma additional checks.
Sub Main
	Dim oApp As Inventor.Application = ThisApplication
	If oApp.Documents.Count = 0
		MsgBox("A drawing document must be open and active",,"iLogic")
		Exit Sub
	End If
	If Not oApp.ActiveDocumentType=DocumentTypeEnum.kDrawingDocumentObject Then
		Exit Sub
	End If
	Dim MyDrawDoc As DrawingDocument=ThisDoc.Document
	If MyDrawDoc.FullDocumentName = "" Then
		MsgBox("The drawing document needs to be saved before", , "iLogic")
		Exit Sub
	End If
	Dim mySavePath As String = GetPath(MyDrawDoc)
	MsgBox(mySavePath)
End Sub
Try
			sNewPath = sNewPath & "$Fabrication Data\"
			bFound = True
		End If
	Next
	'onlöy return path if folder $Fabrication Data was found
	If bfound=True Then
		Return snewpath
	Else
		Return Nothing
	End If
Catch ex As Exception
	MsgBox(ex)
	Return Nothing
End Try
End Function
R. Krieg
RKW Solutions
I see 🙂 it works very well! I got it implemented with my publishing code. Now the only issue is that it wont create missing folders xD Very very close here! Your code was brilliant, I was just not understanding.
I inserted this into Sub Main:
If Not System.IO.Directory.Exists(mySavePath) Then
    System.IO.Directory.CreateDirectory(mySavePath)
End If
 Now all is perfect! I really appreciate the help!!
I would like to display a warning message if the PDF already exist. The user would then have the option "yes" to proceed with publishing or "No" to stop the rule for running. I tried this and it ran, but it overrode the existing PDF and didnt display a warning first:
	If System.IO.Directory.Exists(oDataMedium.FileName) Then Answer = MessageBox.Show("PDF ALready Exists. Override?", "WARNING", MessageBoxButtons.YesNo)
		If Answer = vbNo Then
			Return
		Else
		End If
Ralf_Krieg
Hello
If you want to know a file exist, then don't ask for directory exist.
If System.IO.File.Exists(oDataMedium.FileName) Then Answer = MessageBox.Show("PDF Already Exists. Override?", "WARNING", MessageBoxButtons.YesNo)
	Return
Else
End If
R. Krieg
RKW Solutions
