ilogic to export only certain named sketches from all parts in an assembly
busturazz
busturazz
trying to export all sketches from an assembly with the name "cut DXF sketch". this is not the same as flat pattern as the sketch  has been altered from flat pattern. here is what I have been able to find and piece together. just need to figure out how to have it only export the sketches named "cut DXF Sketch"
'define the active document as an assembly file
Dim oAsmDoc As AssemblyDocument
oAsmDoc = ThisApplication.ActiveDocument
oAsmName = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) -4)
'check that the active document is an assembly file
If ThisApplication.ActiveDocument.DocumentType <> kAssemblyDocumentObject Then
MessageBox.Show("Please run this rule from the assembly file.", "iLogic")
Exit Sub
'get user input
RUsure = MessageBox.Show ( _
"This will create a DXF file for all of the asembly components that are sheet metal." _
& vbLf & "This rule expects that the part file is saved." _
& vbLf & " " _
& vbLf & "Are you sure you want to create DXF for all of the assembly components?" _
& vbLf & "This could take a while.", "iLogic - Batch Output DXFs ",MessageBoxButtons.YesNo)
If RUsure = vbNo Then
Return
Else
oPath = ThisDoc.Path
oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
oContext = ThisApplication.TransientObjects.CreateTranslationContext
oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism
oOptions = ThisApplication.TransientObjects.CreateNameValueMap
'get DXF target folder path
oFolder = oPath & "\" & oAsmName & " DXF Files"
'Check for the DXF folder and create it if it does not exist
If Not System.IO.Directory.Exists(oFolder) Then
System.IO.Directory.CreateDirectory(oFolder)
'- - - - - - - - - - - - -Component - - - - - - - - - - - -
'look at the files referenced by the assembly
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oAsmDoc.AllReferencedDocuments
Dim oRefDoc As Document
'work the the drawing files for the referenced models
'this expects that the model has been saved
For Each oRefDoc In oRefDocs
iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
'check that model is saved
If(System.IO.File.Exists(iptPathName)) Then
Dim oDrawDoc As PartDocument
oDrawDoc = ThisApplication.Documents.Open(iptPathName, True)
oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
Try
'Set the DXF target file name
Try
CustomName =iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR")
Catch
CustomName ="XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert
End Try
oDataMedium.FileName = oFolder & "\" & CustomName  & " " & oFileName & ".dxf"
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDrawDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
oCompDef.Unfold
Else
oCompDef.FlatPattern.Edit
Dim sOut As String
sOut = "FLAT PATTERN DXF?AcadVersion=2010&RebaseGeometry=True&SimplifySpline=True&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL&SplineToleranceDouble=0.01"
oCompDef.DataIO.WriteDataToFile( sOut, oDataMedium.FileName)
'just for check its works coretcly
'i=MessageBox.Show(oDataMedium.FileName, "Title",MessageBoxButtons.OKCancel)
'MessageBox.Show(i,"title",MessageBoxButtons.OK)
'If i=2 Then
'Exit Sub
'End If
oCompDef.FlatPattern.ExitEdit
Catch
End Try
oDrawDoc.Close
Else
Next
JelteDeJong
does this work for you?
[ilogic code]
Dim oAsmDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmName As String = Left(oAsmDoc.DisplayName, Len(oAsmDoc.DisplayName) - 4)
If ThisApplication.ActiveDocument.DocumentType <> DocumentTypeEnum.kAssemblyDocumentObject Then
    Exit Sub
'get user input
Dim RUsure As DialogResult = MessageBox.Show(
    & vbLf & " " _
    & vbLf & "This could take a while.", "iLogic - Batch Output DXFs ", MessageBoxButtons.YesNo)
If RUsure = DialogResult.No Then
    Return
Else
Dim oPath As String = ThisDoc.Path
Dim oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
Dim oContext = ThisApplication.TransientObjects.CreateTranslationContext
Dim oOptions = ThisApplication.TransientObjects.CreateNameValueMap
Dim oFolder = oPath & "\" & oAsmName & " DXF Files"
Dim oRefDocs As DocumentsEnumerator = oAsmDoc.AllReferencedDocuments
For Each oRefDoc As Document In oRefDocs
    Dim iptPathName = Left(oRefDoc.FullDocumentName, Len(oRefDoc.FullDocumentName) - 3) & "ipt"
    If (System.IO.File.Exists(iptPathName)) Then
        Dim oFileName = Left(oRefDoc.DisplayName, Len(oRefDoc.DisplayName))
        Try
            Dim CustomName As String
            Try
                CustomName = iProperties.Value(oFileName, "Custom", "PF_PRT_ZNR")
            Catch
                CustomName = "XXX" 'Wert, wenn iPropertie PF_PRT_ZNR nicht existiert
            End Try
            Dim oCompDef As SheetMetalComponentDefinition = oDrawDoc.ComponentDefinition
                oCompDef.Unfold()
            Else
                oCompDef.FlatPattern.Edit()
            Dim sOut As String
            ' sOut = "FLAT PATTERN DXF?AcadVersion=2010&RebaseGeometry=True&SimplifySpline=True&InteriorProfilesLayer=IV_INTERIOR_PROFILES&InvisibleLayers=IV_TANGENT;IV_BEND;IV_BEND_DOWN;IV_TOOL_CENTER_DOWN;IV_ARC_CENTERS;IV_FEATURE_PROFILES;IV_FEATURE_PROFILES_DOWN;IV_UNCONSUMED_SKETCHES;IV_ROLL_TANGENT;IV_ROLL&SplineToleranceDouble=0.01"
            sOut = "DXF"
            For Each sketch As PlanarSketch In oCompDef.FlatPattern.Sketches
                If Sketch.Name.Equals("cut DXF Sketch") Then
                    Sketch.DataIO.WriteDataToFile(sOut, oDataMedium.FileName)
            Next
            ' oCompDef.DataIO.WriteDataToFile(sOut, oDataMedium.FileName)
            'If i=2 Then
            'Exit Sub
            'End If
            oCompDef.FlatPattern.ExitEdit()
        Catch ex As Exception
        End Try
        oDrawDoc.Close()
    Else
Next
Jelte de Jong
Blog: hjalte.nl - github.com
busturazz
yes as far as i can tell ran a quick test and worked at pulling 1 file will have to try it on an assembly with multiple files
