How to get UCS difference between two parts? Hard to explain...
viktorkulik
Message 1 of 15
viktorkulik
Here's the problem:
I have a part1 and part2 in assembly, i want to get origin + vector data from part2 in relationship to part1. If part1 moves, I want to update part 2 transformation to match their previous location (in relationship to each other).
So far I tried this:
Call p1t.GetCoordinateSystem(origin1, xAxis1, yAxis1, zAxis1)
Call p2t.GetCoordinateSystem(origin2, xAxis2, yAxis2, zAxis2)
This gives me the location data I want, but only in relationship to the Assembly file UCS. Getting the difference of the Origin seems somewhat straight forward, but getting the vector difference is making my brain hurt. Is there an easy way to do this? (programmatically, without using constraints)
Replies (14)
Message 2 of 15
FINET_Laurent
To make it clear, if part 2 move, you want the part 1 to do the same movement?
have a nice day,
FINET L.
If this post solved your question, please kindly mark it as "Solution"
If this post helped out in any way to solve your question, please drop a "Like"
@LinkedIn     @JohnCockerill
Message 3 of 15
Michael.Navara
For manipulating with occurrences use its property Transformation.
If you want to synchronize transformations of two occurrences it is very simple (SyncGCS)
Dim oAsm As AssemblyDocument = ThisDoc.Document
Dim occ1 As ComponentOccurrence = oAsm.ComponentDefinition.Occurrences(1)
Dim occ2 As ComponentOccurrence = oAsm.ComponentDefinition.Occurrences(2)
occ2.Transformation = occ1.Transformation
If you want to synchronize position using UCS, you can use following code where calculation with matrices is used. (SyncUCS)
Sub Main
	Dim T1 As Matrix = GetUcsTransformationMatrix(occ1)
	Dim T2 As Matrix = GetUcsTransformationMatrix(occ2)
	Dim T As Matrix = occ1.Transformation.Copy
	T.PostMultiplyBy(T1)
	T2.Invert()
	T.PostMultiplyBy(T2)
	occ2.Transformation = T
End Sub
Function GetUcsTransformationMatrix(occ As ComponentOccurrence) As Matrix
	Dim compDef As PartComponentDefinition = occ.Definition
	Dim transformationMatrix As Matrix = compDef.UserCoordinateSystems(1).Transformation.Copy
	Return transformationMatrix
End Function
Full iLogic sample is in attachment.
Message 4 of 15
viktorkulik
That is correct.
Message 5 of 15
viktorkulik
Thank you, a couple of questions, in the first example you're simply copying the matrix which will move both parts to the same origin and orientation. What I am after is something like this:
2 parts are placed into assembly, the user spaces them apart a certain distance and rotates them in some way. Then I take a snapshot of both of the locations using by saving the matrix of each.
After this a user can move part1 anywhere  and rotate in any way, the second part will need to be able to sync up to the same location as it was in reference to part1.
The second example doesn't appear to be what I am after either, but i'm digging into it for another reason.
Message 6 of 15
FINET_Laurent
You could get the position of both part,
Substract the coordinates from both parts to get the relative position of  the parts.
Then define the new part1 coordinates as:
xAxis = ( xAxis 2 - xRelativePosistion)
let's say part1 is on x = 150 and part 2 on x = 500
Then relative x position = 500 - 150 = 350
so xAxis1 = xAxis2 - 350
..........hope i made myself clear lmao..
Have a nice day.
Message 7 of 15
viktorkulik
Thanks, yea i'm the one that's having a hard time making myself clear. But to answer your question, that is what I'm attempting, currently I'm just doing that by subtracting each cell of the matrix, to determine the relative location + orientation. Are you saying you can actually subtract Point from Point? or just manually subtract?
Doing this through the matrix.cell seems pretty quick so I may just keep to that, but if there's a method that already does this, i'm all ears.
Message 8 of 15
FINET_Laurent
I'be been digging a bit but i can't seem to find a way.. 😞
Message 9 of 15
viktorkulik
So i need some help understanding why SubtractVector and AddVector don't return a perfect numbers, the angles are like 90.00000000022575364, which then causes an error when I try to SetCoordinateSystem. Is there a way to round the results? Here's my basic demo script, button1 records the locations of both objects, and button2 updates the location of part2 based on a new location of part1. Everything works great while i move the part around, but as soon as I free-rotate a bit, it fails.
Dim origin1 As Point
Dim origin2 As Point
Dim xAxis1 As Vector
Dim yAxis1 As Vector
Dim zAxis1 As Vector
Dim xAxis2 As Vector
Dim yAxis2 As Vector
Dim zAxis2 As Vector
Private Sub CommandButton1_Click()
Set oAsm = ThisApplication.ActiveDocument
Set occ1 = oAsm.ComponentDefinition.Occurrences(1)
Set occ2 = oAsm.ComponentDefinition.Occurrences(2)
Dim oTransform1 As Matrix
Set oTransform1 = occ1.Transformation
Dim oTransform2 As Matrix
Set oTransform2 = occ2.Transformation
Call oTransform1.GetCoordinateSystem(origin1, xAxis1, yAxis1, zAxis1)
Call oTransform2.GetCoordinateSystem(origin2, xAxis2, yAxis2, zAxis2)
End Sub
Private Sub CommandButton2_Click()
Dim origin3 As Point
Dim xAxis3 As Vector
Dim yAxis3 As Vector
Dim zAxis3 As Vector
Call oTransform1.GetCoordinateSystem(origin3, xAxis3, yAxis3, zAxis3)
Dim xa As Vector
Dim ya As Vector
Dim za As Vector
Dim o As Point
Call xAxis2.SubtractVector(xAxis1)
Call yAxis2.SubtractVector(yAxis1)
Call zAxis2.SubtractVector(zAxis1)
Call xAxis2.AddVector(xAxis3)
Call yAxis2.AddVector(yAxis3)
Call zAxis2.AddVector(zAxis3)
Set o = AddPoint(SubtractPoint(origin2, origin1), origin3)
Call oTransform2.SetCoordinateSystem(origin2, xAxis2, yAxis2, zAxis2)
Dim a As Double
a = xAxis2.AngleTo(yAxis2)
a = xAxis2.AngleTo(zAxis2)
a = yAxis2.AngleTo(zAxis2)
occ2.Transformation = oTransform2
End Sub
Function SubtractPoint(p1 As Point, p2 As Point) As Point
Dim p As Point
Set p = ThisApplication.TransientGeometry.CreatePoint(p1.x - p2.x, p1.Y - p2.Y, p1.Z - p2.Z)
Set SubtractPoint = p
End Function
Function AddPoint(p1 As Point, p2 As Point) As Point
Dim p As Point
Set p = ThisApplication.TransientGeometry.CreatePoint(p1.x + p2.x, p1.Y + p2.Y, p1.Z + p2.Z)
Set AddPoint = p
End Function
Message 10 of 15
viktorkulik
Actually the variation on the angle between the X & Y & Z vectors ranges between 89 to 91 degrees, causing the SetCoordinateSystem to fail.
Message 11 of 15
viktorkulik
With updating the matrix manually it works but not all the time, its really odd, small rotation changes get applied but then all of a sudden it will fail. I even tried adding the Round function to see if it would work better but not really
Private Sub CommandButton3_Click()
    Set m1 = occ1.Transformation
    Set m2 = occ2.Transformation
End Sub
Private Sub CommandButton4_Click()
    Set m3 = occ1.Transformation
    Dim dl As Integer
    dl = 20
    m2.Cell(1, 1) = Round(m2.Cell(1, 1), dl) - Round(m1.Cell(1, 1), dl) + Round(m3.Cell(1, 1), dl)
    m2.Cell(1, 2) = Round(m2.Cell(1, 2), dl) - Round(m1.Cell(1, 2), dl) + Round(m3.Cell(1, 2), dl)
    m2.Cell(1, 3) = Round(m2.Cell(1, 3), dl) - Round(m1.Cell(1, 3), dl) + Round(m3.Cell(1, 3), dl)
    m2.Cell(2, 1) = Round(m2.Cell(2, 1), dl) - Round(m1.Cell(2, 1), dl) + Round(m3.Cell(2, 1), dl)
    m2.Cell(2, 2) = Round(m2.Cell(2, 2), dl) - Round(m1.Cell(2, 2), dl) + Round(m3.Cell(2, 2), dl)
    m2.Cell(2, 3) = Round(m2.Cell(2, 3), dl) - Round(m1.Cell(2, 3), dl) + Round(m3.Cell(2, 3), dl)
    m2.Cell(3, 1) = Round(m2.Cell(3, 1), dl) - Round(m1.Cell(3, 1), dl) + Round(m3.Cell(3, 1), dl)
    m2.Cell(3, 2) = Round(m2.Cell(3, 2), dl) - Round(m1.Cell(3, 2), dl) + Round(m3.Cell(3, 2), dl)
    m2.Cell(3, 3) = Round(m2.Cell(3, 3), dl) - Round(m1.Cell(3, 3), dl) + Round(m3.Cell(3, 3), dl)
    occ2.Transformation = m2
End Sub
Message 12 of 15
Michael.Navara
You don't need to calculate coordinate system manually. You can store transformation as object directly. I use iLogic SharedVariable for this.
Store relative position between two occurrences
Dim T1 As Matrix = occ1.Transformation
Dim T2 As Matrix = occ2.Transformation
'Transformation between two Occurrences
Dim T As Matrix = T1.Copy()
T.Invert
'Store result for future use
SharedVariable("RelativePosition") = T
Restore relative position
'Restore relative position from StoreRelativePosition rule
Dim T As Matrix = SharedVariable("RelativePosition")
'Calculate new T2
Dim T2 As Matrix = occ1.Transformation.Copy
T2.PostMultiplyBy(T)
'Apply
occ2.Transformation = T2
Message 13 of 15
Michael.Navara
You can't calculate final transformation matrix as add and subtract cell values. Standard transformation matrix consists of submatrix of direction cosines, translation vector and constant values.
| direction : X |
| _cosines_ : Y |
| __here__  : Z |
|  0  0  0  : 1 |
When you combine two or more transformation matrices, you must always use MULTIPLICATION of matrices instead of ADD or SUBTRACT
Beware when you multiply matrices T1 x T2 is NOT the same as T2 x T1
See some resources of matrix calculations. For example here: https://en.wikipedia.org/wiki/Matrix_(mathematics)
Message 14 of 15
viktorkulik
Thanks, the invert & postmultiply was exactly what I needed, appreciate your help! The main reason why i was not saving the matrix was because i need to be able to store this information outside of inventor, so i was just testing how that would work.
Thanks.
Message 15 of 15
viktorkulik
That makes sense, thanks Michael.
