iLogic to Create Drawing with Flat Pattern View
kara_johnsonLG2ZG
kara_johnsonLG2ZG
Dim oCompDef As SheetMetalComponentDefinition
oCompDef = oDoc.ComponentDefinition
If oCompDef.HasFlatPattern = False Then
	MessageBox.Show("Please create flat pattern")
	Exit Sub
End If
Dim oDrawingDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,templateFile,True)
oDrawingDoc.Activate()
Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
Dim oView1, oView2, oView3 As DrawingView
Dim oTopRightPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width * 2 / 3, oSheet.Height * 2 / 3)
Dim oLeftPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oSheet.Width / 3, oSheet.Height / 2)
oView1 = oSheet.DrawingViews.AddBaseView(oDoc, oTopRightPoint, 1/8, ViewOrientationTypeEnum.kIsoTopRightViewOrientation, DrawingViewStyleEnum.kShadedDrawingViewStyle)
oView2 = oSheet.DrawingViews.AddBaseView(oDoc, oTopRightPoint, 1/8, ViewOrientationTypeEnum.kFlatBacksideViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle)
Dim oProjectedPoint As Point2d = ThisApplication.TransientGeometry.CreatePoint2d(oView2.Center.X, oView2.Center.Y -10)
oView3 = oSheet.DrawingViews.AddProjectedView(oView2, oProjectedPoint, DrawingViewStyleEnum.kFromBaseDrawingViewStyle)
I am creating an iLogic rule to automatically create drawings and place a couple of views. We are working with sheet metal and I would like to place a flat view. However, when I run my code, it says "the parameter is incorrect". I've narrowed this down to being the flat view orientation parameter (the red text).
The ipt does have a flat pattern (and I also check if it has one in the code). If I try and edit the view that it does place (Iso Top Right), the flat pattern bubble is greyed out. But if I manually create a new base view, I can select flat pattern.
Any ideas what I'm doing wrong?
CGBenner
@kara_johnsonLG2ZG
Welcome to the Community!  I moved your post here because this is where all of the programmers hang out.  Good luck!
Chris Benner
patrick.schlambHPACQ
Dim oViewOptions As NameValueMap = ThisApplication.TransientObjects.CreateNameValueMap
oViewOptions.Add("SheetMetalFoldedModel", False)
oView2 = oSheet.DrawingViews.AddBaseView(oDoc, oTopRightPoint, 1/8, ViewOrientationTypeEnum.kBackViewOrientation, DrawingViewStyleEnum.kHiddenLineRemovedDrawingViewStyle, AdditionalOptions := oViewOptions)
'oView2
 I have commented out your line and replaced it with a line I have used to successfully create flat pattern views in a drawing. I tried to match it to your existing code and variable, but may have missed something. Please let me know if this helps with your issue.
kara_johnsonLG2ZG
Worked! Thank you so much for your help!
AkshayM9WQXB
I tried your code but I'm getting an error as
"Rule Compile Errors in Rule Temp 2, in P1.ipt
Error on Line 2 : 'oDoc' is not declared. It may be inaccessible due to its protection level." Why is that? I need to do same, to place flat pattern, and have section views for that folded part by placing the folded part over the flat pattern and an Iso view. Could you please help me with this? Thank you.
AkshayM9WQXB
I have also attached the dwg file so you have an idea on what I am looking for. I want something like that. The folded part which is sectioned is place on the flat pattern and then it is suppressed after having section views so we only are left with flat pattern, section views and ISO view. Thank you.
