iLogic to create custom iProperty for certain parts of assembly
jishee
jishee
I want to create a custom iProperty for parts that have an already defined custom iProperty called "Routing". Below is the code I have so far. Every time I run it I get an error message that says "Cannot find a property named "Routing." I know that there are parts in the assembly with the "Routing" property in them. Any suggestions would be appreciated.
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = ThisApplication.ActiveDocument.ComponentDefinition
'Conversion factor cm to in
Dim oCF As Double = 0.393701
Dim oX As Double = 0
Dim oZ As Double = 0
'Iterate through all Of the occurrences
Dim oOcc As ComponentOccurrence
For Each oOcc In oAsmCompDef.Occurrences.AllReferencedOccurrences(oAsmCompDef)
	'Check for infills and skip virtual components
	If iProperties.Value(oOcc.Name, "Custom", "Routing") = "_I" And Not TypeOf oOcc.Definition Is VirtualComponentDefinition Then
	  	oX = (oOcc.Definition.RangeBox.MaxPoint.X - oOcc.Definition.RangeBox.MinPoint.X)*oCF
		oZ = (oOcc.Definition.RangeBox.MaxPoint.Z - oOcc.Definition.RangeBox.MinPoint.Z) * oCF
		Try 'write to component iprops
			iProperties.Value(oOcc.Name, "Custom", "Width") = iProperties.Value("Custom", "Width")
			iProperties.Value(oOcc.Name, "Custom", "Height") = iProperties.Value("Custom", "Height")
		Catch 'catch errors
			'create iprop with default value
			iProperties.Value("Custom", "Width") = Round(oZ, 3)
			iProperties.Value("Custom", "Height") = Round(oX, 3)
		End Try
Next
WCrihfield
Try it this way, and see if it works.  I put an extra loop in there to check if the custom iProperty exists or not.  If you're just creating a new custom iProperty, or are just changing the value of an existing custom iProperty, using the iProperties.Value() method is fine, but if you're just trying to check the value of a custom iProperty that may not be there, you either need to use a Try...Catch statement around it, or search for it first, so it won't throw an error when not found.
Dim oOccDoc As Document
Dim oPropSet As PropertySet
Dim oProp As [Property]
	If oOcc.Definition.Type <> ObjectTypeEnum.kVirtualComponentDefinitionObject Then
		oOccDoc = oOcc.Definition.Document
		oPropSet = oOccDoc.PropertySets.Item("Inventor User Defined Properties")
		For Each oProp In oPropSet
			If oProp.Name = "Routing" Then
				If oProp.Value = "_I" Then
					oX = (oOcc.Definition.RangeBox.MaxPoint.X - oOcc.Definition.RangeBox.MinPoint.X) * oCF
					Catch 'catch errors
					End Try
		Next
Next
Also, not sure if this will work for this situation or not, but it may be faster or more efficiant to loop through Each oRefDoc As Document In oAssemblyDoc.AllReferencedDocuments to do this.  It doesn't accound for VirtualComponents, but they probably don't have externally saved files.
Wesley Crihfield
(Not an Autodesk Employee)
jishee
@WCrihfield  thanks for your help. The fixes you made run without error and add the width and height properties like expected but do no fill in any values. I am missing something with the range box? I just want the dimensions in the X and Z directions for the parts.
marcin_otręba
try this code:
						oPropSet.item("Width1").Value = Round(oZ, 3)
						oPropSet.item("Height1").Value= Round(oX, 3)
					Catch 'catch errors
						      oPropSet.Add(Round(oZ, 3),  "Width1")
						      oPropSet.Add(Round(oX, 3),  "Height1")
					End Try
		Next
Next
Hi, maybe you want to check my apps:
DrawingTools   View&ColoringTools   MRUFolders
jishee
That works as expected. Thank you for your help @WCrihfield  and @marcin_otręba !
