iLogic to create copy
Hello all, I need help coding iLogic to make a copy of the open model under a diferent name is a pre determined location with the same extension.
Any help would be greatly appreciated, I have been searching for the answer but can't find exactly what I need
jdkriek
Here you go 😉
Dim Path As String = "C:\Temp\"
Dim FileName As String = "yourfilename"
Dim ext() = Split(ThisDoc.FileName(True), ".")
ThisDoc.Document.SaveAs(Path & FileName & "." & ext(1), True)
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Thank you sir it worked great!!!!
jdkriek
You're welcome. Glad it worked for you.
Jonathan D. Kriek
