Ilogic to create browser tree folders (ONLY IF NOT EXIST)
amarcoc
Message 1 of 14
amarcoc
Hi.
How can I create new folders in Inventor browser tree, using ilogic (ONLY IF NOT EXIST)?
Thanks in advance!
Replies (13)
Message 2 of 14
Owner2229
EDIT: I just saw the "only if not exists"...
EDIT2: Fixed the ComponentDefinition
Here you go:
Dim oFolderName As String = "NewFolder"
Dim oDoc As Document = ThisApplication.ActiveDocument Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane Dim oFolder As BrowserFolder = Nothing Try oFolder = oPane.BrowserFolders(oFolderName) Catch oFolder = oPane.AddBrowserFolder(oFolderName, Nothing) End Try
If in assembly, you can pass it occurrences you want to be added to the folder:
Dim oDoc As Document = ThisApplication.ActiveDocument Dim oNodes As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane For Each oOcc As ComponentOccurrence In oDoc.ComponentDefinition.Occurrences Dim oNode As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc) oNodes.Add(oNode) Next
Dim oFolder As BrowserFolder = Nothing Try oFolder = oPane.BrowserFolders(oFolderName) Catch oFolder = oPane.AddBrowserFolder(oFolderName, oNodes) End Try
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
Message 3 of 14
amarcoc
EDIT: check next post
Message 4 of 14
amarcoc
The code on first updated code part creates new folder even if exist. The second generates error as in previous post 😞
Message 5 of 14
Owner2229
Alright, so there's a little bit more into that than I thought. Here's the correction:
Dim oDoc As Document = ThisApplication.ActiveDocument Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane Dim oFolder As BrowserFolder = Nothing Try oFolder = oPane.TopNode.BrowserFolders(oFolderName) Catch oFolder = oPane.AddBrowserFolder(oFolderName, Nothing) End Try
The Assembly one:
Dim oFolder As BrowserFolder = Nothing Try oFolder = oPane.TopNode.BrowserFolders(oFolderName) Catch oFolder = oPane.AddBrowserFolder(oFolderName, oNodes) End Try
Mike
Message 6 of 14
amarcoc
Thank you.
First code works perfect. How about using an array to create multiple folders, if not exist?
Message 7 of 14
Owner2229
Sure thing:
Dim oFN() As String = {"NewFolder", "OldFolder", "AnotherFolder"}
For Each oFolderName As String In oFN
	Try
	Catch
	End Try
Next
Mike
Message 8 of 14
amarcoc
EDIT:
It worked perfect.
You're great.
Thanks!
Message 9 of 14
Owner2229
Hmm, that's strange. I've just tested it and it worked.
Why did you enclose it in a Sub() ?
Do you call it from somewhere? If not, either change it to "Sub Main()" or remove it.
As always, you're welcomed.
Mike
Message 10 of 14
amarcoc
meanwhile I edited my last comment.
Worked perfect.
Thanks.
Message 11 of 14
amarcoc
Hi again
I need a small update on this ilogic if possible: if a folder with name "XYZ" is found, then rename it to "ABC".
Could you help me on this?
Thanks!
Message 12 of 14
Owner2229
Sure, here it is in the current rule:
Dim oFN() As String = {"XYZ", "OldFolder", "AnotherFolder"}
	Try
	Catch
	End Try
	If oFolderName = "XYZ" Then oFolder.Name = "ABC"
Next
As a standalone one:
Dim oFolderName As String = "XYZ"
Dim oNewName As String = "ABC"
Try
	Dim oFolder As BrowserFolder = oPane.TopNode.BrowserFolders(oFolderName)
	oFolder.Name = oNewName
Catch
End Try
Mike
Message 13 of 14
amarcoc
Again, thank you.
Older folder is not renamed.
Its renamed only if I move the rename line, as this:
	Try
	Catch
	End Try
Next
But even this dont work well on first try.
Any idea?
Message 14 of 14
@Owner2229 wrote:
Sure thing:
	Try
	Catch
	End Try
Next
Top notch!
Is there a code for deleting those 3 folders in your code? So that you could go back and forth?
