iLogic to create browser node folder and move all iParts and iAssemblies into it
Message 1 of 10
Hi Guys....
I found a good code doing what i need but only for:
'	If TypeOf oOcc.Definition Is VirtualComponentDefinition Then
'	If TypeOf oOcc.Definition Is PartComponentDefinition Then
 ... how is it possible do to same now for iPart and iAssembly?
This code I am using now:
'define folder name to use
sFolder = "Parts"
'define assembly doc
Dim oDoc As AssemblyDocument
oDoc = ThisApplication.ActiveDocument
'define assembly Component Definition
Dim oAsmCompDef As AssemblyComponentDefinition
oAsmCompDef = oDoc.ComponentDefinition
'get browser pane
Dim oPane As BrowserPane
oPane = oDoc.BrowserPanes.ActivePane
'try to get existing folder by name and delete it
'catch error if not found
Dim oFolder As BrowserFolder
Try
	oFolder = oPane.TopNode.BrowserFolders(sFolder)
	oFolder.Delete
Catch
End Try
Dim oCollection As ObjectCollection
oCollection = ThisApplication.TransientObjects.CreateObjectCollection
'Iterate through all of the occurrences in the assembly
Dim oOcc As ComponentOccurrence
For Each oOcc In oAsmCompDef.Occurrences
	'look at only virtual components
		'get browser node of occurence
	    Dim oNode As BrowserNode
        oNode = oPane.GetBrowserNodeFromObject(oOcc)
		'add node to collection
		oCollection.Add(oNode)
Next
Can someone help me here please . Thanks
Replies (9)
Message 2 of 10
UPDATE:
I managed now to define the folder name via input - define the part section via name(wildcard) and in the end select the definition type from a list window. Works great so far but what I can't manage currently is WorkPlanes. Did someone know how to this? This is my code so far:
 oMyParameter = ThisApplication.ActiveDocument.ComponentDefinition.Parameters.UserParameters
Try
'Change value of param
Parameter("TypeOfItem") = ""
Catch
'Create Param as it doesn't exist
oParameter=oMyParameter.AddByValue("TypeOfItem", "", UnitsTypeEnum.kTextUnits)
End Try
sFolder = InputBox("Input Folder Name", "BrowserNodeFolder Name", "** Folder Name**")
itemName = InputBox("Input Wildcard of Item you want to put in the folder", "BrowserNodeItem Name", "** Item Name**")
MultiValue.SetList("TypeOfItem", "Part", "Assembly", "VirtualItem")
ItemType = InputListBox("Choose Item Type Definition", MultiValue.List("TypeOfItem"),ItemType,Title := "Type of Item Definition", ListName := "Available Standard Item Types")
'get browser pane
Try
	oFolder.Delete
Catch
End Try
Dim part As String = "Part"
Dim assembly As String = "Assembly"
Dim virtual As String = "VirtualItem"
'part = TypeOf oOcc.Definition Is PartComponentDefinition
'assembly = TypeOf oOcc.Definition Is AssemblyComponentDefinition
'virtual = TypeOf oOcc.Definition Is AssemblyComponentDefinition
'    If TypeOf oOcc.Definition Is AssemblyComponentDefinition Then
If oOcc.Name.Contains(itemName) And ItemType = part Then
If oOcc.Name.Contains(itemName) And ItemType = assembly Then
	    Dim oNode1 As BrowserNode
        oNode1 = oPane.GetBrowserNodeFromObject(oOcc)
		oCollection.Add(oNode1)
If oOcc.Name.Contains(itemName) And ItemType = virtual Then
	    Dim oNode2 As BrowserNode
        oNode2 = oPane.GetBrowserNodeFromObject(oOcc)
		oCollection.Add(oNode2)
Next
' recreate folder
'And add collection To folder
Try
oFolder = oPane.AddBrowserFolder(sFolder,oCollection)
Catch
MessageBox.Show("Error happens here", "ilogic")
End Try
 As well if I type same folder name it will not add to already existing folder it will swap - means already selected items getting moved back to browser node and new selected items getting moved to browser node folder.
Jens
Message 3 of 10
maxim.teleguz
The code is much better faster and places the folders on the bottom even if you accidently press cancel or type in a number of a part that doesn't exist (it would be nice to have a check but I think that would take too long):
sFolder = itemName
If sFolder = "" Then
	Exit Sub
Else If sFolder = "** Item Name**"
	MsgBox("please enter item number")
	Exit Sub
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument
Dim oAsmCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition
'get browser pane
'Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane
Dim oPane As BrowserPane = oDoc.BrowserPanes("Model")
Dim oTopNode As BrowserNode = oPane.TopNode
Try
	oFolder = oPane.TopNode.BrowserFolders.Item(sFolder)
	oFolder.Delete
Catch
End Try
Dim oCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection
If oOcc.Name.Contains(itemName) And Inventor.DocumentTypeEnum.kPartDocumentObject Then
	    Dim oNode As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc)
If oOcc.Name.Contains(itemName) And Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
	    Dim oNode1 As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc)
Next
' recreate folder
Try
	oFolder = oPane.AddBrowserFolder(sFolder, oCollection)
Catch
	MessageBox.Show("Error", "ilogic")
End Try
Message 4 of 10
Ryan.Stewart
Is there a way to add code to only use the occurrences that are 8 characters long?
Message 5 of 10
maxim.teleguz
that should be really easy to do that, but why? this is a manual click on part in feature tree and it creates a folder for them.
Message 6 of 10
Ryan.Stewart
I am using the rule now to sort my browser and put my 96 parts in a folder and my 97 part in a folder.  But with the wild card  it is also getting some of my files that are project specific but have 96 or 97 in the part name.  They are longer file names similar to this example "123496-00".  But this file name would be moved to the folder also since it has a 96 in the file name.
Message 7 of 10
maxim.teleguz
ill think on this
Message 8 of 10
maxim.teleguz
this is my latest updated code. go to feature tree and click on the part you want to be in a folder
Sub main
Dim oDoc As AssemblyDocument = ThisApplication.ActiveDocument 'define assembly doc
Dim oAsmCompDef As AssemblyComponentDefinition = oDoc.ComponentDefinition 'define assembly Component Definition
startagain :
SendKeys.SendWait("{ESC}")
AppActivate(ThisApplication.Caption)
c = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select component")
If c Is Nothing Then
	Exit Sub
Else
	'get displayed string since that is what some content center parts show as.
	Dim originalString As String = c.name
	Dim symbol As String = ":"
	' Find the position of the symbol
	Dim indexOfSymbol As Integer = originalString.IndexOf(symbol)
	' Check if the symbol is present in the string
	If indexOfSymbol <> -1 Then
	    ' Extract the portion of the string before the symbol
	    Dim resultString As String = originalString.Substring(0, indexOfSymbol)
	    'MsgBox(resultString)
		f = resultString
	Else
	    ' Symbol not found in the string
	    'MsgBox("Symbol not found in the string.")
'If c Is Nothing Then
'	Exit Sub
'Else
'	d = Component.InventorComponent(c.name).Definition.Document.FullFileName 'get the path and file name of the selected item
'	f = IO.Path.GetFileNameWithoutExtension(d)
'	MsgBox(f)
'	'Exit Sub
'End If
'this works for display name too, keeping just in case for future reference. needs the function below to work
'Dim c As Object = ThisApplication.CommandManager.Pick(SelectionFilterEnum.kAllEntitiesFilter, "Select component")
'    Exit Sub
'Else
'    Dim selectedComponent As ComponentOccurrence = TryCast(c, ComponentOccurrence)
'    If selectedComponent IsNot Nothing Then
'        ' For assembly components, get the display name from ComponentOccurrence
'        Dim displayName As String = selectedComponent.Name
'        MsgBox(displayName)
'    Else
'        ' For parts, get the display name from BrowserNodeDefinition.Label
'        Dim partNode As BrowserNode = ThisApplication.ActiveDocument.BrowserPanes.ActivePane.GetBrowserNodeFromObject(c)
'        Dim displayName As String = GetDisplayName(partNode)
'    End If
'	Exit Sub
'End If
'f = InputBox("Input Wildcard of Item you want to put in the folder", "BrowserNodeItem Name", "****")
'sFolder = f
If f = "" Then
	Exit Sub
Else If f = "** Item Name**"
Exit Sub
Dim oPane As BrowserPane = oDoc.BrowserPanes.ActivePane 'get browser pane
Dim oTopNode As BrowserNode = oPane.TopNode 'get browser pane top node
Try 'try to get existing folder by name and delete it
	oFolder = oPane.TopNode.BrowserFolders.Item(f)'filenamewithoutextension
	oFolder.Delete
Catch 'catch error if not found
End Try
Dim oCollection As ObjectCollection = ThisApplication.TransientObjects.CreateObjectCollection 'create a bucket to put stuff in
Dim oOcc As ComponentOccurrence 'Iterate through all of the occurrences in the assembly
	If oOcc.Name.Contains(f) And Inventor.DocumentTypeEnum.kPartDocumentObject Then
			Dim oNode As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc) 'get browser node of occurence
			oCollection.Add(oNode) 'add node to collection
			'MsgBox(f)
	If oOcc.Name.Contains(f) And Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
			Dim oNode1 As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc) 'get browser node of occurence
			oCollection.Add(oNode1) 'add node to collection
'this also works really well to compare like something keeping just in case for future reference.
'	If oOcc.Name.Contains(oOcc.Name Like c.name) And Inventor.DocumentTypeEnum.kPartDocumentObject Then
'			Dim oNode As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc) 'get browser node of occurence
'			oCollection.Add(oNode) 'add node to collection
'			'MsgBox(f)
'		End If
'	End If
'	If oOcc.Name.Contains(oOcc.Name Like c.name) And Inventor.DocumentTypeEnum.kAssemblyDocumentObject Then
'			Dim oNode1 As BrowserNode = oPane.GetBrowserNodeFromObject(oOcc) 'get browser node of occurence
'			oCollection.Add(oNode1) 'add node to collection
'		End If
'	End If
Next
Try
	oFolder = oPane.AddBrowserFolder(f, oCollection) 'recreate folder & add collection To folder
Catch
End Try
oFolder.BrowserNode.DoSelect 'select folder that was created so that it you can stay in place.
GoTo startagain
'SOURCECODE: https://forums.autodesk.com/t5/inventor-forum/ilogic-to-create-browser-node-folder-and-move-all-iparts-and/td-p/9000788
End Sub
'Private Function GetDisplayName(node As BrowserNode) As String
'    Dim label As String = ""
'    If node.BrowserNodeDefinition.Type = ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
'        Dim compOcc As ComponentOccurrence = TryCast(node.BrowserNodeDefinition, ComponentOccurrence)
'        If compOcc IsNot Nothing Then
'            label = compOcc.Name
'        End If
'    Else
'        label = node.BrowserNodeDefinition.Label.ToString()
'    End If
'    Return label
'End Function
Message 9 of 10
Ryan.Stewart
Not lazy it saves me time not having to search thru the browser with my common fasteners or purchased part and only work with the project specific parts.
Message 10 of 10
Ryan.Stewart
The second ilogic version works great with what I am doing but it gets files that contain the 96 number in it.  I am VERY new to logic, Is there an easy way to limit adding the file to my folder if it is not a library part?  All my library parts are an 8-digit number.
