iLogic Sheet size
iLogic Sheet size
Cosmin_V
iLogic Sheet size
Cosmin_V
Hi
I try to make a drawing directly from an assembly, but I have a problem to set the sheet size.
Is somebody there who can help me?
This is the rule I work on....
Dim  oDoc As Document
oDoc = ThisDoc.Document
Dim templateFile As String
templateFile = "C:\WF\CAD\Inventor 2016\Templates\CUN\CUN.idw"  '''Place the path of your template idw
Dim oDrawingDoc As DrawingDocument = ThisApplication.Documents.Add(DocumentTypeEnum.kDrawingDocumentObject,templateFile,True)
oDrawingDoc.Activate()
Dim oSheet As Sheet = oDrawingDoc.Sheets.Item(1)
Dim oSize As SheetFormat = sheetSize
Dim oPoint1 As Point2d
oPoint1 = ThisApplication.TransientGeometry.CreatePoint2d(40, 30)
Dim oView As DrawingView
oView = oSheet.DrawingViews.AddBaseView(oDoc,oPoint1, 1/2, ViewOrientationTypeEnum.kFrontViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Dim oPoint2 As Point2d
oPoint2 = ThisApplication.TransientGeometry.CreatePoint2d(15, 30)
oView = oSheet.DrawingViews.AddBaseView(oDoc,oPoint2, 1/2, ViewOrientationTypeEnum.kRightViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Dim oPoint3 As Point2d
oPoint3 = ThisApplication.TransientGeometry.CreatePoint2d(60, 30)
oView = oSheet.DrawingViews.AddBaseView(oDoc,oPoint3, 1/2, ViewOrientationTypeEnum.kLeftViewOrientation, DrawingViewStyleEnum.kHiddenLineDrawingViewStyle)
Dim oPoint4 As Point2d
oPoint4 = ThisApplication.TransientGeometry.CreatePoint2d(70, 15)
oView = oSheet.DrawingViews.AddBaseView(oDoc,oPoint4, 1/2, ViewOrientationTypeEnum.kIsoTopRightViewOrientation, DrawingViewStyleEnum.kShadedDrawingViewStyle)
oDoc.ReleaseReference
Thank You
SašoPrijatelj
Hi.
This should work:
oSheet.Size = DrawingSheetSizeEnum.kA0DrawingSheetSize
Replace kA0DrawingSheetSize with the size you actually want.
Best regards,
Sašo
AutoDXF - automatic flat pattern creation and batch export to DXF for Inventor
Please use "Accept as Solution" & give "Kudos" if this response helped you.
Cosmin_V
Thank You  saso
Is Ok, is open the sheet which I wont but now the border is stil from A1...
SašoPrijatelj
After changing the sheet size you also have to change the border. There are 2 ways: using iLogic function SetBorder or using VB approach. Both are described in Vladimir's post here:
https://forums.autodesk.com/t5/inventor-customization/ilogic-change-drawing-borders-from-assembly/td...
