iLogic to copy material to document
gert-leonvanlier
gert-leonvanlier
I am tryin to write some iLogic code to check if particular materials (plural) exists in de local document and if not copy the materials to the document. I found this in the help. The materials to check on I placed in an array. A for each should then go through this array and check if the material exists and if not copy it to the document. Unfortunately it does not work like this. When I change the 'i' in the for each to for example "Yellow Paint" it works.
What am I doing wrong?
Dim oDoc As PartDocument = ThisDoc.Document
Dim oCompDef As ComponentDefinition = oDoc.ComponentDefinition
Dim oBody As SurfaceBody
Dim assetLib As AssetLibrary
Dim localAsset As Asset
Dim libAsset As Asset
Dim Material As Object
Dim i As Integer
materialArray = New String() {
	MainColour & "Paint",
	"Belt",
	"Black Paint",
	"Roller",
	"Steel"
i = 1
For Each Material In materialArray
	On Error Resume Next
	localAsset = oDoc.Assets.Item(i)
	If Err.Number <> 0 Then
		On Error GoTo 0
		assetLib = ThisApplication.AssetLibraries.Item("MHSEMaterialLibrary")
		libAsset = assetLib.AppearanceAssets.Item(i)
		localAsset = libAsset.CopyTo(oDoc)
	End If
	i = i + 1
Next
Sergio.D.Suárez
Hi, I can not try the following code because I do not have that personalized library. I suppose that every item within the matrix should be inside this library.
See if it can help you.
	"Belt",
	"Black Paint",
	"Roller",
	"Steel"
For i As Integer =0 To UBound(materialArray)
	Try
	Catch
		localAsset = oDoc.Assets(i)
	End Try
Next
 I hope you can solve your problem. regards
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
gert-leonvanlier
I changed my code to this and this works:
Dim materialArray As New ArrayList
Dim i As Integer
materialArray.Add(MainColour & " Paint")
materialArray.Add("MHS Belt")
materialArray.Add("Black Paint")
materialArray.Add("MHS Roller")
materialArray.Add("Steel")
i = 0
	localAsset = oDoc.Assets.Item(materialArray(i))
		On Error GoTo 0
		libAsset = assetLib.AppearanceAssets.Item(materialArray(i))
	End If
	i = i + 1
Next
 EDIT:
And this also works:
i = 0
	Try
	Catch
	End Try
	i = i + 1
Next
rschader
In the last code segment you shared, you can eliminate the "i" counter  if you change it to:
i = 0
	'libAsset = assetLib.AppearanceAssets.Item(materialArray(i))
libAsset = assetLib.AppearanceAssets.Item(Material) Try localAsset = libAsset.CopyTo(oDoc) Catch localAsset = oDoc.Assets.Item(materialArray(i)) End Try i = i + 1 Next
I commented out the line referencing i for the array index. You should also change it in the catch portion, which I just now noticed.
