iLogic to convert tolerance in a drawing
Rony4491
Rony4491
Hi everyone,
I'm trying to find a way to convert some tolerances in a drawing using iLogic, because I have many drawing to check.
For example I have "10 +0.02/0" or "20 ±0.05" and I want to :
1. Test if it's a symmetric, deviation or default tolerance for each dimension in my drawing.
2. Get the 1 or 2 values (+0.02, 0,etc...) and test it (if it's more than 1, go to the next dimension).
3. Change +0.02/0 to +20/0 and change ±0.05 to ±50.
Best regards
chandra.shekar.g
Autodesk Support
Autodesk Support
@Rony4491,
Every dimension object contains Tolerance object. From Tolerance object, Type can be determined. For more details, refer sample API program link.
http://help.autodesk.com/view/INVNTOR/2019/ENU/?guid=GUID-066D6B4E-CE84-4727-AFC9-ADB196EC08F9
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
Rony4491
Hello thanks for your answer, but I got a 404 error when I click on it..
chandra.shekar.g
Autodesk Support
Autodesk Support
@Rony4491 ,
Try this link.
https://help.autodesk.com/view/INVNTOR/2020/ENU/?guid=GUID-066D6B4E-CE84-4727-AFC9-ADB196EC08F9
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
