iLogic to change the view representation in a part file
sebastien008
sebastien008
Hi all,
so Far this is what i capture online,
oApp = ThisApplicationMsgBox("hahahah")If oApp.ActiveDocument.DocumentType = kdrawingDocumentObject ThenDim odrawdoc As DrawingDocumentodrawdoc = ThisApplication.ActiveDocumentFor Each oActivesheetViewrep In odrawdoc.Sheets.Item(1).DrawingViews.Item(1).ActiveDesignViewRepresentationIf oActivesheetViewrep.Name = "Master" ThenoActivesheetViewrep.ActivateOn Error Resume NextElseEnd IfNextElseMsgBox("Assembly Document Is Not Open")End If
It works well on assembly drawing and part ipt
but what i need is simple ... or not
The scrip would be as per below :
when 2D drafter on DWG chose the view to be draw
the reprensentation will  not be "master" by default but set up to a condition
for exemple is the iproperty custom category type = details
then representation view will be detail and not master,
hope i'm really clear ^^
please help
VdVeek
sebastien008, if i understand you correct.
By default when placing a view on a drawing the view that was last active in the part shows up as drawing view. So isn't it posible to set the appropriate view representation in the part before closing it. Then when creating a drawing of that part, you know which view is set as default. Or are you trying to automate the creatition of drawings?
Rob.
Autodesk Inventor 2015 Certified Professional & Autodesk Inventor 2012 Certified Professional.
sebastien008
Hi rob , first thx as you are the first you reply to my question 😉
My concerne is more complexe since i use LOD as layout to avoid shoing all the detail to customer but when i detail i used detail 😉 for fabrication drawing 😉
Sent from my iPhone
sebastien008
Pleasee see attached below my issues,
in Level of detail in my Layout i'm forced due to the weight of our equipment to creat a Level of detail ( LAYOUT) which is less detail no brand ....
But when i'm focus on the detail drawing dwg .... I would like the drawing to catch the Iproperty CATEGORY TYPE created as DETAIL since 3D drafter already know that he will need a detail drawing .
And if it's in category type DETAILS then LOD should automaticly choose DETAIL
Hope my screenshot will help
