ilogic to change selected dims to basic tol.
I would like to be able to pick dimensions (overall size dim.)
Then change the tolorance to basic.
I have found this rule that changes all dims,
I just need to add the the pick function then change the picked dims.
Any help adding pick then changing to tol basic, not all dims.
Thank
Referance rule....
' Set a reference to the select set of the active document. Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument ' Find all selected occurrences and add them to an ObjectCollection. Dim oDrawingDims As DrawingDimension 'Loop through all dimensions For Each oDrawingDims In oDoc.ActiveSheet.DrawingDimensions 'set the Tolerance Method'oDrawingDims.Tolerance.SetToDefault oDrawingDims.Tolerance.SetToBasic 'oDrawingDims.Tolerance.SetToReference Next
You were right there, You were just missing 2 or 3 lines of code! Select the dimensions then run the rule.
Dim oSSet As SelectSet = oDoc.SelectSet
For Each oDrawingDims In oSSet
Next
maxim.teleguz
this is really useful
nathan_m_gardner
Can I get a full copy of this macro? I want to be able to change dims to ref. thanks
I have it:
Sub ToggleToleranceReferenceDefault()
Set oDoc = ThisApplication.ActiveDocument
Set oSSet = oDoc.SelectSet
Next
End Sub
