07:17 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I would like to be able to pick dimensions (overall size dim.)
Then change the tolorance to basic.
I have found this rule that changes all dims,
I just need to add the the pick function then change the picked dims.
Any help adding pick then changing to tol basic, not all dims.
Thank
Referance rule....
' Set a reference to the select set of the active document. Dim oDoc As DrawingDocument oDoc = ThisApplication.ActiveDocument ' Find all selected occurrences and add them to an ObjectCollection. Dim oDrawingDims As DrawingDimension 'Loop through all dimensions For Each oDrawingDims In oDoc.ActiveSheet.DrawingDimensions 'set the Tolerance Method'oDrawingDims.Tolerance.SetToDefault oDrawingDims.Tolerance.SetToBasic 'oDrawingDims.Tolerance.SetToReference Next
