iLogic to change Mate offset
does any one know how i would go about using ilogic to change the mate offset?
is there some type of code like constraint.offset("mate:xxx", ##)?
blandb
If your mate is parameter d2, Offset, or whatever name you chose, then just change the parameter say d2 = 1, 5, 0.5, etc. at the assembly level rule. For instance if that value is supposed to change based on another value:
If X = 3 Then
d2 = 0.5
else
d2 = 0
End if
Hope that helps.
Autodesk Certified Professional
Got it - I realize now that it was a slightly silly question! I didn't think about setting the parameter itself equal to the value and was instead trying to figure out something with the mate as a whole! Thanks for your help!!
