Alright, we can try something like this:
Imports System
AddReference "System.Drawing.dll"
Imports System.Windows.Forms
Sub Main()
iPro_Mat = "Material-iPro-Name"
iPro_Des = "Description-iPro-Name"
Dim Mat_List() As String = {"123456", "234567"}
Dim Desc_List() As String = {"Desc1", "Desc2"}
CreateForm("MyReplacingForm")
AddLB(5, 5, "Material to replace:", 160)
AddLB(5, 32, "Replacing material:", 160)
AddCB(170, 5, Mat_List, 150)
AddCB(170, 32, Mat_List, 150)
AddLB(5, 75, "Description to replace:", 160)
AddLB(5, 102, "Replacing description:", 160)
AddCB(170, 75, Desc_List, 150)
AddCB(170, 102, Desc_List, 150)
Dim oBT As Button = AddBT(0, 0, "REPLACE")
Dim PosX As Integer = MF.Width - (oBT.Width * 1.3) - 80
Dim PosY As Integer = MF.Height - (oBT.Height * 3)
oBT.Location = New Drawing.Point(PosX, PosY)
AddHandler oBT.Click, AddressOf Me.Replace
MF.ShowDialog()
End Sub
Private Sub Replace()
Dim Val1 As String = CB(0).Text
Dim Val2 As String = CB(1).Text
Dim Val3 As String = CB(2).Text
Dim Val4 As String = CB(3).Text
If Val1 = vbNullString And Val3 = vbNullString Then Exit Sub
Dim oDoc As Document = ThisApplication.ActiveDocument
For Each iDoc As Document In oDoc.AllReferencedDocuments
If Val1 <> vbNullString Then
Dim ValX As String = iPropertyUser(iDoc, iPro_Mat).Expression
If ValX = Val1 Then iPropertyUser(iDoc, iPro_Mat).Expression = Val2
End If
If Val3 <> vbNullString Then
Dim ValX As String = iPropertyUser(iDoc, iPro_Des).Expression
If ValX = Val3 Then iPropertyUser(iDoc, iPro_Des).Expression = Val4
End If
Next
End Sub
Private Function iPropertyUser(oDoc As Inventor.Document, oProp As String) As Inventor.Property
Dim oPropsets As PropertySets = oDoc.PropertySets
Dim oPropSet As PropertySet = oPropsets.Item("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
Try
iPropertyUser = oPropSet.Item(oProp)
Catch
oPropSet.Add("", oProp)
End Try
oPropsets = Nothing
oPropSet = Nothing
End Function
Private iPro_Mat As String
Private iPro_Des As String
Private MF As Form
Private BT(0) As Button
Private CB(0) As ComboBox
Private LB(0) As Label
Private Sub CreateForm(Optional Name As String = vbNullString)
MF = New Form
MF.Text = Name
MF.AutoScaleMode = AutoScaleMode.None
MF.Size = New Drawing.Size(350, 210) 'Width, Heigth
MF.MinimumSize = MF.Size
MF.MaximumSize = MF.Size
MF.Font = New Drawing.Font(MF.Font.FontFamily, 10)
MF.MaximizeBox = False
MF.MinimizeBox = False
MF.ShowIcon = False
MF.SizeGripStyle = SizeGripStyle.Hide
MF.StartPosition = FormStartPosition.CenterScreen
AddExitButton()
End Sub
Private Function AddLB(PosX As Integer, PosY As Integer, Optional Caption As String = vbNullString, Optional Width As Integer = 100) As Label
Dim LC As Integer = LB.Length - 1
If Not LB(LC) Is Nothing Then
LC = LC + 1
ReDim Preserve LB(LC)
End If
LB(LC) = New Label
LB(LC).Name = "L" & LC
LB(LC).Location = New Drawing.Point(PosX, PosY)
LB(LC).Text = Caption
LB(LC).Width = Width
MF.Controls.Add(LB(LC))
Return LB(LC)
End Function
Private Function AddCB(PosX As Integer, PosY As Integer, Values() As String, Optional Width As Integer = 100) As ComboBox
Dim LC As Integer = CB.Length - 1
If Not CB(LC) Is Nothing Then
LC = LC + 1
ReDim Preserve CB(LC)
End If
CB(LC) = New ComboBox
CB(LC).Location = New Drawing.Point(PosX, PosY)
CB(LC).Name = "CB" & LC
CB(LC).Width = Width
For Each Value As String In Values
CB(LC).Items.Add(Value)
Next
MF.Controls.Add(CB(LC))
Return CB(LC)
End Function
Private Function AddBT(PosX As Integer, PosY As Integer, Caption As String, Optional Width As Integer = 80) As Button
Dim LC As Integer = BT.Length - 1
If Not BT(LC) Is Nothing Then
LC = LC + 1
ReDim Preserve BT(LC)
End If
BT(LC) = New Button
BT(LC).Name = "BT" & LC
BT(LC).Location = New Drawing.Point(PosX, PosY)
BT(LC).Text = Caption
BT(LC).Width = Width
MF.Controls.Add(BT(LC))
Return BT(LC)
End Function
Private Sub AddExitButton()
Dim oBT As Button = AddBT(0, 0, "OK")
AddHandler oBT.Click, AddressOf Me.ExitButtonClick
End Sub
Private Sub ExitButtonClick()
MF.Close()
End Sub
Consider using "Accept as Solution" / "Kudos" if you find this helpful.
Mike
"Always code as if the guy who ends up maintaining your code will be a violent psychopath who knows where you live." - John F. Woods
