iLogic to change iParts help needed
Thomas_Savage
Advisor Advisor
Message 1 of 9
Thomas_Savage
Looking for some help, possibly an easy solution, just can't figure it out.
I have a multi value list of: 1000,1500,2000
When i select one of these from my form i want iLogic to change the iPart to the correct size.
I can do this with 1000 and 1500. Because i have the names to change the iPart. But when i add 2000 then i don't have the correct part name to change them back. If this makes sense?
I have attached my code, if anyone could help me with my code to add 2000, so can select 1000, 1500, 2000 and will always change that would be much appreciated.
Thomas.
If iPart_Size_Change = 1500 Then
iPart.ChangeRow("UNLP-5132-17:6", "UNLP-5131-17")
If iPart_Size_Change = 1000 Then
iPart.ChangeRow("UNLP-5131-17:6", "UNLP-5132-17")
iPart.ChangeRow("UNLP-5132-17:5", "UNLP-5131-17")
iPart.ChangeRow("UNLP-5131-17:5", "UNLP-5132-17")
Thomas Savage
Design Engineer
Replies (8)
Message 2 of 9
AlexFielder
I assume that each of the values you want corresponds with one of 1000, 1500, 2000? - in your code you have 1000 & 1500 paired to one iPart row, but then you change what they're paired with.
1000 = iPart.ChangeRow("UNLP-5131-17:6", "UNLP-5132-17")
1500 = iPart.ChangeRow("UNLP-5132-17:5", "UNLP-5131-17")
2000 = ??
If you can supply whichever iPart row you want 2000 to refer to then we can probably arrive at a solution.
Message 3 of 9
Thomas_Savage
Thank you for the reply.
This is what happens. If i make 1500 part change 2000 part if works ok. But this is where i get the problem. Because then i can't change the 2000 back to 1000 or 1500. Becasue it can't find the ipart. My code below.
'Change iPart
If iPart_Size_Change = 2000 Then
iPart.ChangeRow("UNLP-5131-17:6", "UNLP-5130-17")
Thomas Savage
Design Engineer
Message 4 of 9
Thomas_Savage
Some more details which could help.
I have a pattern, i am trying to change the iPart i have patterned. But come up the error because it can't find the part to change.
Is they a easier way to change iParts than this??
I want to change it 3 times.
Any help much appreciated,
Thomas.
Thomas Savage
Design Engineer
Message 5 of 9
AlexFielder
can you share the offending part file? (or a similar example if you have IP concerns)
Message 6 of 9
Thomas_Savage
I have made some parts and attached them.
I want to be able to change all these iParts to the different sizes without an error coming up.
How can i do this?
I know i need to apply a codes o the pattern moves with it. I have done this on my model, just stuck on this.
thank you for your help.
Thomas
Thomas Savage
Design Engineer
Message 7 of 9
Thomas_Savage
I have Solved this problem.
Code Attached.
Thank you for replying to me post.
Thomas
'Change iPart
	iPart.ChangeRow("UNLP-5132-17 (iLogic)", "UNLP-5132-17")
	ElseIf iPart_Size_Change = 1500
	iPart.ChangeRow("UNLP-5132-17 (iLogic)", "UNLP-5131-17")
	ElseIf iPart_Size_Change = 2000
	iPart.ChangeRow("UNLP-5132-17 (iLogic)", "UNLP-5130-17")
	iPart.ChangeRow("UNLP-5132-17 (iLogic 2)", "UNLP-5132-17")
	iPart.ChangeRow("UNLP-5132-17 (iLogic 2)", "UNLP-5131-17")
	iPart.ChangeRow("UNLP-5132-17 (iLogic 2)", "UNLP-5130-17")
Thomas Savage
Design Engineer
Message 8 of 9
AlexFielder
It seems like you've solved this, but attached is an assembly I put together that might be useful to you (and others)
It has two rules:
"replace iParts"
Sub main()
	Component.Replace(Parameter("CurrentRelevantOccurrences"), ReplacingComponent(iPartToReplace & ".ipt"), False)
	iLogicVb.RunRule("get current relevant iParts")
End Sub
Function ReplacingComponent(ReplacementComp As String) As String
	Logger.Debug("replacing: " & Parameter("CurrentRelevantOccurrences") & " With: " & Parameter("iPartToReplace") & ".ipt")
	Return iPartToReplace & ".ipt"
End Function
And a second more complex rule that gets the relevant occurrences currently in the assembly:
Sub main()
	GetCurrentRelevantOccurences()
End Sub
Sub GetCurrentRelevantOccurences()
	If TypeOf ThisApplication.ActiveDocument Is AssemblyDocument Then
		Dim AssyDoc As AssemblyDocument = ThisApplication.ActiveDocument
		Dim assyDef As AssemblyComponentDefinition = AssyDoc.ComponentDefinition
		Dim occurrenceList As List(Of String) = New List(Of String)
		Dim allowedList As List(Of String) = ListOfAllowedOccurrences
		For Each allowedOcc As String In allowedList
			Dim DocTocheck As Document = ThisApplication.Documents.ItemByName(IO.Path.GetDirectoryName(AssyDoc.FullDocumentName) & "\" & allowedOcc)
			If Not DocTocheck Is Nothing Then
				For Each compOcc As ComponentOccurrence In assyDef.Occurrences.AllReferencedOccurrences(DocTocheck)
					Dim tmpDoc As PartDocument = compOcc.Definition.Document
					If Not tmpDoc Is Nothing Then
						occurrenceList.Add(compOcc.Name)
				Next
		Next
		occurrenceList.Sort()
		MultiValue.List("CurrentRelevantOccurrences").Clear
		MultiValue.List("CurrentRelevantOccurrences") = occurrenceList
End Sub
Function ListOfAllowedOccurrences() As List(Of String)
	Dim tmpList As List(Of String) = New List(Of String)
	tmpList.Add("1000.ipt")
	tmpList.Add("1500.ipt")
	tmpList.Add("2000.ipt")
	Return tmpList
End Function
You can edit the "ListOfAllowedOccurrences" function to affect what items appear when you run the "Click Me!" form within the assembly file.
Message 9 of 9
Thomas_Savage
Hello @AlexFielder
thank you for those codes, and taking the time to help me.
Thomas.
Thomas Savage
Design Engineer
