iLogic to change bacground
TA.Fehr
Message 1 of 8
TA.Fehr
I've written two iLogic codes that change the bacground colour to white before save (so the thumbnail shows the part/assembly cleanly), and then after save to revert to the original colours. The code exists in each part and is triggered to run the same way for each part.
The code works perfectly on single parts, and on assemblies where all the sub-components are open within Inventor.
However, when I make changes and save at the assembly level (while the sub-components are not open in Inventor) the code stops running after the first rule. Manually running the second rule reverts the changes, but the sub-components do not update their respective thumbnails as per the first example.
Because the rules are triggered by the save command I had to split the code into pre and post save otherwise it would error out. The code saves the bacground color to the part location to retrieve after thet save, and then deletes the txt file. I considered making this an external rule, but this would cause issues when we send any parts/assemblies to our clients.
The first rule triggered to run before the save is:
SyntaxEditor Code Snippet
fs = CreateObject("Scripting.FileSystemObject")
OldColorFile = fs.CreateTextFile(ThisDoc.Path & "\" & ThisDoc.FileName(False) & "OldColorName.txt", True)
Dim OldColorSchemeName As String
OldColorSchemeName = ThisApplication.ActiveColorScheme.Name
OldColorFile.WriteLine (OldColorSchemeName)
OldColorFile.Close
OldBackgroundFile = fs.CreateTextFile(ThisDoc.Path & "\" & ThisDoc.FileName(False) & "OldBackground.txt", True)
Dim OldBackground As BackgroundTypeEnum
OldBackground = ThisApplication.ColorSchemes.BackgroundType
OldBackgroundFile.WriteLine (OldBackground)
OldBackgroundFile.Close
ThisApplication.ColorSchemes.Item("Presentation").Activate
ThisApplication.ColorSchemes.BackgroundType = 52737
 The second rule, which is triggered to run after the save is:
Imports System.IO
Dim oRead As New StreamReader(ThisDoc.Path & "\" & ThisDoc.FileName(False) & "OldBackground.txt")
Dim aLine As String
aLine = oRead.readline()
oRead.Close
Kill (ThisDoc.Path & "\" & ThisDoc.FileName(False) & "OldBackground.txt")
Dim Read As New Streamreader(ThisDoc.Path & "\" & ThisDoc.FileName(False) & "OldColorName.txt")
Dim bLine As String
bLine = Read.readline()
Read.Close
Kill (ThisDoc.Path & "\" & ThisDoc.FileName(False) & "OldColorName.txt")
ThisApplication.ColorSchemes.Item(bline).Activate
ThisApplication.ColorSchemes.BackgroundType = aline
ThisApplication.GeneralOptions.Show3DIndicator = True
Replies (7)
Message 2 of 8
PaulMunford
Thomas Rambach (@CadToolBox) had a plugin that did this. I can't find it with a web search, so I've tweeted him to see If he can help us out...
Paul Munford
Technical Onboarding Architect
Linkedin
Message 3 of 8
PaulMunford
Here it is...
http://cadtoolbox.com/all-thumbs/
Paul Munford
Linkedin
Message 4 of 8
TA.Fehr
Thanks for the link, but the download is unavailable. I spoke with my co-worker who got me working on the code and he had found this same plug-in. However, the plug-in is no longer updated and contacting the creator gave me code very similar to what I've written above.
I'm guessing the Dev ran into the same issue I'm finding and figured it wasn't worth his time.
Message 5 of 8
Message 6 of 8
I'm not sure how this translates to iLogic yet but All Thumbs fires for a Save and checks if onBefore or onAfter. For onBefore it saves the current application settings and stores them temporarily. It then switches to the thumbs setting and finishes the save. Inventor then fires the same Save command but flagged as onAfter where All Thumbs reverts back to the original application settings. All Thumbs is written in VB:
Private Sub oAppEvents_OnSaveDocument(ByVal DocumentObject As Inventor._Document, ByVal BeforeOrAfter As Inventor.EventTimingEnum, ByVal Context As Inventor.NameValueMap, ByRef HandlingCode As Inventor.HandlingCodeEnum) Handles oAppEvents.OnSaveDocument
DoAllThumbs(BeforeOrAfter)
End Sub
If BeforeOrAfter = EventTimingEnum.kBefore Then
'## Do Something
Else
'## Do Something Else
End If
Message 7 of 8
JohnKHouston
Hi Thomas,
I'm using Inventor 2020 and I tried the All Thumbs and it appeared to work correctly, but it didn't save the info for my background type. I prefer to use gradient instead of one color. When All Thumbs switched back, it switched to one color, unfortunately.
Is there any way I can modify the code you posted so that All Thumbs will save the background type? I know it's not supported any more so if you can't find the time, I understand. I just had to ask because it's so close to being what I need.
Thanks in advance.
Best regards,
John Houston
Message 8 of 8
@JohnKHouston you can capture that information by using:
The options are  BackgroundTypeEnum.kGradientBackgroundType, BackgroundTypeEnum.kImageBackgroundType or BackgroundTypeEnum.kOneColorBackgroundType.
