iLogic to Assign New Part Numbers and List Unchanged Files
Jonathan.CharltonE35Y2
Message 1 of 10
I'm using Inventor Professional 2022 64-Bit, Build 492, Release: 2022.4.1.
I have a rule that I'm trying to use to assign new part numbers to all components in the Parts Only view of the BOM of an assembly.
It's been working well, but needs more error catching functionality.
I just need it to display a message box and show what parts it couldn't modify (Content Center component, Library Part, Suppressed part, etc.
I'm still a novice when it comes to iLogic, but I've been able to patch together this code after reading posts online.
Could someone explain how I could achieve what I'm wanting to do?
Public Sub Main()
    Dim oAssemblyDocument As AssemblyDocument
    oAssemblyDocument= ThisDoc.Document
    Dim oAssemblyComponentDefinition As AssemblyComponentDefinition
    oAssemblyComponentDefinition = oAssemblyDocument.ComponentDefinition
    Dim oAsmCustomPropSet As PropertySet = oAssemblyDocument.PropertySets.Item("Inventor User Defined Properties")
    Dim oAsmSkidNumber As String
    Dim oAsmSkidLetter As String
    Try
            'Get current custom prop value
            oAsmSkidNumber = iProperties.Value("Custom", "SKID NUMBER")
            oAsmSkidLetter = iProperties.Value("Custom", "SKID LETTER")
    Catch
            'Assume error means prop not found so create it
            oAsmCustomPropSet.Add("", "SKID NUMBER")
            oAsmCustomPropSet.Add("", "SKID LETTER")
            'Get User input
            oAsmSkidNumber = InputBox("Please enter a Skid Number", "iLogic", oAsmSkidNumber)
            oAsmSkidLetter = InputBox("Please enter a Skid Letter", "iLogic", oAsmSkidLetter)
            'Set custom prop value
            iProperties.Value("Custom", "SKID NUMBER") = oAsmSkidNumber
            iProperties.Value("Custom", "SKID LETTER") = oAsmSkidLetter
    End Try
    Dim oBOM As BOM
    oBOM = oAssemblyComponentDefinition.BOM
    oBOM.PartsOnlyViewEnabled = True
    Dim oBOMView As BOMView
    oBOMView = oBOM.BOMViews.Item("Parts Only") 'or structured
    Try
        oBOMView.Sort("Description", True,)
        oBOMView.Renumber(1, 1)
    Catch
        MessageBox.Show("The program has failed. There are no parts to renumber.", "Error", MessageBoxButtons.OK, MessageBoxIcon.Stop)
        Exit Sub
    End Try
    For Each oBOMRow As BOMRow In oBOMView.BOMRows
	        Try
				Dim oComponentDefinition As ComponentDefinition
				oComponentDefinition = oBOMRow.ComponentDefinitions.Item(1)
				MsgBox("anything")
	            Dim oBOMItemNumber As String
	            oBOMItemNumber = oBOMRow.ItemNumber() 'this is item number in the BOM
	            Dim oAsmSkidDesignation As String = oAsmSkidNumber & "-" & oAsmSkidLetter & "-" & oBOMItemNumber
	            Dim oComponentDefinitionPropertySet As PropertySet
	            oComponentDefinitionPropertySet = oComponentDefinition.Document.PropertySets.Item("Design Tracking Properties")
	                'Project property tab
	            oComponentDefinitionPropertySet.Item("Part Number").Value = oAsmSkidDesignation
	                'populates the Part Number property
	        Catch
				MsgBox("anything")
				Dim oPropSets As PropertySets = oComponentDefinition.PropertySets
				Dim oPropSet As PropertySet = oPropSets.Item("Design Tracking Properties")
				Dim oPN As [Property] = oPropSet.Item("Part Number")
				Dim oPNText As String = oPN
				MessageBox.Show("The following components were unchanged: " & oPNText, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
			End Try
		Next
End Sub
Replies (9)
Message 2 of 10
A.Acheson
Hi @Jonathan.CharltonE35Y2
One line that will help you a lot is IsModifiable and here is the location to find it from the API Help.
When you have got the document object you can check if it is readonly/modifable. If it isn't then it is a CC/Library Part. As for suppressed parts you won't be able to detect that from the BOM I don't believe. You will likely need to loop through all occurrences for that info. Are you using model states?
Syntax
PartDocument.IsModifiable() As Boolean
Regards
Alan
Message 3 of 10
Hey @A.Acheson,
Thanks for the reply.
"One line that will help you a lot is IsModifiable and here is the location to find it from the API Help." - I had tried the .IsModifiable, but I hadn't tried it as a Boolean. I'll add that to the block and test it to see how it runs.
"As for suppressed parts you won't be able to detect that from the BOM I don't believe. You will likely need to loop through all occurrences for that info." - Got it.
"Are you using model states?" - Not at this time.
Your input and advice is very much appreciated.
Message 4 of 10
@A.Acheson,
I've incorporated the PartDocument.IsModifiable() As Boolean snippet into my blocks.
However, I keep getting an error on line 61 stating:
Public member 'IsModifiable' on type 'PartComponentDefinition' not found.
I am a little confused, as it seems that the .IsModifiable() is working in the Try portion of the block, but not in the Catch.
Can you offer some insight as to what I'm doing wrong?
Public Sub Main()
    Try
    Catch
            'Get User input
    End Try
    Dim oBOM As BOM
    Try
    Catch
        Exit Sub
    End Try
			Dim oComponentDefinition As ComponentDefinition = oBOMRow.ComponentDefinitions.Item(1)
			Dim oBOMItemNumber As String = oBOMRow.ItemNumber() 'this is item number in the BOM
			Dim oCompDefPropSet As PropertySet = oComponentDefinition.Document.PropertySets.Item("Design Tracking Properties")
			Dim oCompDefPN As String = oCompDefPropSet.Item("Part Number").Value
	   Try
			If oComponentDefinition.IsModifiable() = True Then
				oCompDefPropSet.Item("Part Number").Value = oAsmSkidDesignation
				End If
		Catch
				If oComponentDefinition.IsModifiable() = False Then
					MessageBox.Show("The following components were unchanged: " & oCompDefPN, "Error", MessageBoxButtons.OK, MessageBoxIcon.Error)
				End If
		End Try
    Next
End Sub
Message 5 of 10
CGBenner
Hi!  Were you able to get this problem resolved, or do you still need some additional help from the Community or @A.Acheson ?
Chris Benner
Message 6 of 10
@CGBenner ,
Hello!
Unfortunately, I was unable to get the code to perform as intended.
I instead opted for a different fix for the time being.
However, I do have some new information available that I haven't had the time to analyze, and will update this post with the functioning code upon completion.
If anyone has any input it is greatly appreciated, as I am still learning and would love to improve my knowledge of iLogic.
Message 7 of 10
A.Acheson
Is Modifiable property check is only available from the document object. So since we know these are only parts then declare the part document like below. Now when you type "." after the declared object the list of available methods and properties comes up and you can search for is Modifiable in that list.
Dim partDoc as PartDocument = oComponentDefinition.Document
If partDoc.IsModifiable = True Then
   Logger.Info("Success " & partDoc.DisplayName & " is Writeable, do something else now")
End If
Regards
Alan
Message 8 of 10
WCrihfield
Hi @Jonathan.CharltonE35Y2.  You requested some resources to help you learn iLogic in a private message, and on the forum, so I have attached a few PDF's that I created a while back that may help some with that.  These are just a few, because we are only allowed to attach 3 items per reply.
Wesley Crihfield
(Not an Autodesk Employee)
Message 9 of 10
WCrihfield
Here are a couple more that you may find interesting/useful.
Wesley Crihfield
Message 10 of 10
@A.Acheson,
Thank you for the detailed explanation and example. As time permits, I will attempt to implement this into my existing code and see if I can't get it to perform as intended. Once the code is working as intended, I will update this post with function code block to help others in the future, should they need it.
Your continued help and support is greatly appreciated!
@WCrihfield,
Thank you for sharing.
I'm looking forward to giving each of these a read, and seeing how I can improve my future code based off the information contained.
Hopefully others can find this post as well, and take advantage of the information provided.
