Ilogic to add dimensions to flat pattern
Does anybody have any ilogic to add dimensions to a flat pattern view in an idw ?
KarelC
Which dimensions do you mean? Automatic dimensions are in context menu.
___________________________________________________________
Dell Precision T3620
Inventor 2019, Autocad Mechanical 2019, Vaul Basic 2019
I have an Ilogic rule that creates 5 views on the drawing sheet and it can retrieve dimensions for the front view.
It places a flat pattern view and I want it to automatically dimension it.
Overall dimensions and fold lines.
Is this possible?
KarelC
Sorry, I didn't create dimensions by macro yet. I think it is possible. I'll try it.
KarelC
Yes, it is possible. I tried VBA macro for drawing dimensions in one view. Here yoy have few steps for drawing dimensions by macro. For iLogic you must make some changes.
First you must find lines wit poit for dimensions
Dim oView As DrawingView
Dim oCurve As DrawingCurve
For Each oCurve In oView.DrawingCurves    '  - finding lines in your view
 'here you chose some lines for dimension
Next
Then transform line points to points for dimension
Dim oPoint As GeometryIntent
Set oPoint = oDocument.ActiveSheet.CreateGeometryIntent(oCurve, kStartPointIntent)  '  - make points for dimesion, you must have two point
One poit for dimension text
Dim oPointForText As Point2d
Finaly draw the dimension
Call oSheet.DrawingDimensions.GeneralDimensions.AddLinear( oPointForText, BodPrvni, BodDruhy, kHorizontalDimensionType)
