I don't want to be rude, but it's easier for everyone if you provide what you already do have.
We can't see how your variables are declared, so to give a fully working example that works in your case without error is quite difficult.
Anyway, i'm glad to help you out if there should be any problems building your code
You can use this piece of ilogic, just place your code where the line is commented
Dim oDrawDoc as drawingdocument = ThisDrawing.Document
Dim oSheet As sheet
For Each oSheet In oDrawDoc.sheets
'Place your code to align dimensions here
'maybe this line is also needed, did not test it
ActiveSheet = ThisDrawing.Sheet(osheet.Name)
Next osheet
If you think this answer fullfilled your needs, improved your knowledge or leads to a solution,
please feel free to "kudos"
