iLogic to Access embedded excel in part from assembly level
andrewiv
Mentor Mentor
andrewiv
I'm trying to access an embedded excel file that is in a part from the assembly that the part is used in.  I can't quite figure it out.  Every time I run this iLogic rule its trying to access a spreadsheet embedded in the assembly.  How can I tell Inventor to look at the part and use the excel embedded there instead of the assembly?
Sub Main()
Dim oDoc As Document
oDoc = ThisApplication.ActiveDocument
Dim oRefDocs As DocumentsEnumerator
oRefDocs = oDoc.AllReferencedDocuments
Dim oRefDoc As Document
	For Each oRefDoc In oRefDocs
		If oRefDoc.DocumentType = kPartDocumentObject Then
		Call Update(oRefDoc)
        Next
End Sub
Function Update(oEditDoc As Document)
Dim oParams As Inventor.Parameters
oParams = oEditDoc.ComponentDefinition.Parameters
oParams.ParameterTables.AddExcelTable("C:\MYEXCELFILE.xlsx", "C42", False)
	oXcel = oEditDoc.ReferencedOLEFileDescriptors.Item(1)
	oXcelName = oXcel.DisplayName
        GoExcel.CellValue("3rd Party:" & oXcelName, "Sheet1", "D2") = Parameter1
	GoExcel.CellValue("3rd Party:" & oXcelName, "Sheet1", "D3") = Parameter2
End Function
Andrew In’t Veld
Designer / CAD Administrator
Sergio.D.Suárez
Hello, try this Ilogic code in the assembly. You must have embedded the excel table inside the parts.
Sub Main()
Dim oDoc As Document = ThisDoc.Document
	For Each oRefDoc As Document In oDoc.AllReferencedDocuments
	Next
End Sub
On Error Resume Next
Dim oTable As ParameterTable
oTable = oParams.ParameterTables.Item(1)
oXLSheet = oTable.WorkSheet
oXLSheet.Cells.Range("D2").Value = Parameter1
oXLSheet.Cells.Range("D3").Value = Parameter2
End Function
The assembly must have defined the parameters "Parameter1" and "Parameter2"
I hope it will be useful and help you solve your problem
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
andrewiv
Thank you, this worked perfectly.  It's good to know you can access the excel sheet through the parameter tables object instead of the referenced OLE file descriptor.
Andrew In’t Veld
