How is "Thread Designation" listed within iLogic
chris
Advisor Advisor
chris
I am trying to create a simple iLogic  part that will change thread sizes based on a couple options... I have used the (Feature: SetThreadAll), which then asks for the following:
featurename
thread type
thread designation
thread class
for some reason, it keeps giving me an error when I choose thread size in the form, it's telling me that the thread designation is not valid....?
I'm using the same format from the IV Excel thread sheet: examples
1/4-20 UNC
1/2-13 UNC
3/4-10 UNC
1-8 UNC
Sergio.D.Suárez
Hi, as the thread class and type are kept constant, I think this code would serve you. I tried it replicating its model and it worked for me.
If Shaft_Size = "1/4" Then Parameter("d28") = 0.25
If Shaft_Size = "1/2" Then Parameter("d28") = 0.5
If Shaft_Size = "3/4" Then Parameter("d28") = 0.75
If Shaft_Size = "1"   Then Parameter("d28") = 1
If Treaded = True Then
	Feature.IsActive("Thread1")=True
	Feature.IsActive("Thread2") = True
Else
	Feature.IsActive("Thread1")=False
	Feature.IsActive("Thread2") = False
iLogicVb.UpdateWhenDone = True
InventorVb.DocumentUpdate()
	Feature.ThreadDesignation("Thread1") = "1/4-20 UNC"
	Feature.ThreadDesignation("Thread2") = "1/4-20 UNC"
	Feature.ThreadDesignation("Thread1") = "1/2-13 UNC"
	Feature.ThreadDesignation("Thread2") = "1/2-13 UNC"
	Feature.ThreadDesignation("Thread1") = "3/4-10 UNC"
	Feature.ThreadDesignation("Thread2") = "3/4-10 UNC"
	Feature.ThreadDesignation("Thread1") = "1-8 UNC"
	Feature.ThreadDesignation("Thread2") = "1-8 UNC"
 I hope the code will be useful.
Please accept as solution and give likes if applicable.
I am attaching my Upwork profile for specific queries.
Sergio Daniel Suarez
Mechanical Designer
| Upwork Profile | LinkedIn
