Hi @manu.marjanen. Here is an iLogic rule you can try out for this task. I did not have a file to test this on, so I have not tested it yet, but it seems fairly simple.
If ThisDoc.Document.DocumentType <> DocumentTypeEnum.kPartDocumentObject Then
MsgBox("A Part Document must be active for this rule to work. Exiting.", vbCritical, "")
Exit Sub
Dim oPDoc As PartDocument = ThisDoc.Document
Dim oPDef As PartComponentDefinition = oPDoc.ComponentDefinition
Dim oThknFeats As ThickenFeatures = oPDef.Features.ThickenFeatures
Dim oWSs As WorkSurfaces = oPDef.WorkSurfaces
If oWSs.Count = 0 Then Exit Sub
Dim oBaseName As String = "Plate-"
Dim oInt As Integer = 1
For Each oWS As WorkSurface In oWSs
Dim oThknFeat As ThickenFeature = oThknFeats.Add(oWS, _
".25 in", PartFeatureExtentDirectionEnum.kPositiveExtentDirection, _
PartFeatureOperationEnum.kNewBodyOperation)
Try
oThknFeat.SurfaceBodies.Item(1).Name = oBaseName & oInt
oInt = oInt + 1
Catch
MsgBox("Error trying to rename new Body, created by the Thicken feature.", vbExclamation, "")
End Try
Next
If this solved your problem, or answered your question, please click ACCEPT SOLUTION .
Or, if this helped you, please click (LIKE or KUDOS) 👍.
Wesley Crihfield
(Not an Autodesk Employee)
