Control scale while create derived part from the given part model with C#
Maxim-CADman77
Advisor Advisor
Maxim-CADman77
I need to create derived part from the given part model with C#
In VB.Net I can do this like:
Dim oDerPrt As PartDocument = oInv.Documents.Add(DocumentTypeEnum.kPartDocumentObject, Nothing, False)
Dim oDerivedPartDef As DerivedPartUniformScaleDef = oDerPrt.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(oPart.FullFileName)
oDerivedPartDef.ScaleFactor = 1
oDerivedPartDef.ExcludeAll()
oDerivedPartDef.UseColorOverridesFromSource = False
oDerivedPartDef.Solids(oSB1.Name).IncludeEntity = True
oDerivedPartDef.Solids(oSB2.Name).IncludeEntity = True
oDerPrt.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef)
My best attempt to convert this to C# for now is:
PartDocument oDerPrt = (PartDocument)oInv.Documents.Add(DocumentTypeEnum.kPartDocumentObject, null, false);
DerivedPartUniformScaleDef oDerivedPartDef = oDerPrt.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(oPart.FullFileName);
oDerivedPartDef.ScaleFactor = 1;
oDerivedPartDef.ExcludeAll();
oDerivedPartDef.UseColorOverridesFromSource = false;
oDerivedPartDef.Solids[oSB1.Name].IncludeEntity = true;
oDerivedPartDef.Solids[oSB2.Name].IncludeEntity = true;
oDerPrt.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef);
But compiler finds error " cannot convert from 'Inventor.DerivedPartUniformScaleDef' to 'Inventor.DerivedPartDefinition' ".
What I'm missing?
Please vote for Inventor-Idea Text Search within Option Names
Maxim-CADman77
The code probably should be:
DerivedPartDefinition oDerivedPartDef = (DerivedPartDefinition)oIPT_Tmp.ComponentDefinition.ReferenceComponents.DerivedPartComponents.CreateUniformScaleDef(oPart.FullFileName);
oDrvPrt.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add(oDerivedPartDef);
But then I need to understand how to control/modify Scale (in case I need it)
jjstr8
In your original code you didn't cast to a DerivedPartDefinition.
oDerPrt.ComponentDefinition.ReferenceComponents.DerivedPartComponents.Add((DerivedPartDefinition)oDerivedPartDef);
Maxim-CADman77
@jjstr8
I wonder...
... cast DerivedPartUniformScaleDef to DerivedPartDefinition possibility ...
... was it just your guessing or what is the source of that knowledge?
jjstr8
@Maxim-CADman77  -  No guesswork required.  It's just what the method requires.  Intellisense in Visual Studio will also show you that when you hover over '.Add'.  The API help shows that DerivedPartCoordinateSystemDef, DerivedPartTransformDef, and DerivedPartUniformScaleDef are all derived classes of DerivedPartDefinition.  Unfortunately the API help example is in VBA, which automatically makes the cast for you.  It's the same situation with the classes derived from the Documents class.
