iLogic supress all constraints
Ezekiel12
Ezekiel12
can someone point me in right direction? Suppress specific constraint relationship in assembly is easy. But how should i proceed if I need to suppress them all?
Thx,
Matt
Curtis_Waguespack
Hi Ezekiel12,
This should do it:
Dim oAssDoc As AssemblyDocument
oAssDoc = ThisApplication.ActiveDocument
Dim oConstraint As AssemblyConstraint
For Each oConstraint In oAssDoc.ComponentDefinition.Constraints
	oConstraint.Suppressed = True
Next
And this to turn them all back on:
	oConstraint.Suppressed = False
Next
I hope this helps.
Curtis
Ezekiel12
Thank you very much, thats exactly it 🙂
Could you suppress and ground all parts using this method? Then also unground and unsuppress all constraints?
RoyWickrama_RWEI
Hi Curtise;
I would like to see the the constraint (say XXX) in the browser. Could you help. Thanks.
'	oConstraint.Suppressed = True
MessageBox.Show("Constraint: " & oConstraint.name, "Title")
oConstraint_Name = "XXX"
'Find constraint XXX in browser Next
R.Mabery
To ground all components, you could add something similar to below (assuming the oAssDoc declaration from Curtis' code is already there):
    ' Iterate through all of the occurrences and ground them.
    Dim oOccurrence As ComponentOccurrence
    For Each oOccurrence In oAssDoc.ComponentDefinition.Occurrences
      oOccurrence.Grounded = True
    Next
Set the Grounded property to False to unground them.
Randy Mabery
Applications Expert
IMAGINiT Technologies
R.Mabery
Hi rwickrama,
I don't know of a way to select the browser node for the constraint, but you can search for it with something like this:
Dim oPane as BrowserPane
oPane = oAssDoc.BrowserPanes("AmBrowserArrangement")
Dim oSearchBox as SearchBox
oSearchBox = oPane.SearchBox
oSearchBox.Enabled = True
oSearchBox.Visible = True
	' Find constraint XXX in browser
	sConName = oConstraint.Name
	MessageBox.Show("Constraint: " & sConName, "Title")
	Call oSearchBox.Search(sConName)
Next
Randy Mabery
Applications Expert
