iLogic (Summary Comments, internal vs external rule not running)
steveh5
Advisor Advisor
steveh5
Tyring to figure out some iLogin on utilizing the mult-line text in iProps.
Have some logic which only runs when it is an internal rule.
Video shows what I'm dealing with....
https://autode.sk/2zxBwa7
Thanks for the help in advance.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
External iLogic rules will not run automatically due to parameter changes, unless you set them to do so via an event trigger.  Document based rules will automatically run on parameter changes by default.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...
If i may ask, why are you writing to both a parameter and an iProperty?  You could point the form at the iProperty instead, changing it directly, with no iLogic involved.
