iLogic (Reuse iProp and value, but change multiValue List)
steveh5
Advisor Advisor
steveh5
Attempting to create an iLogic rule which re-uses and iProp and it's value, but update the multiValue list to new listing.
Video shows what I'm dealing with .....
https://autode.sk/2TZm5jw
Thank you for the help!
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
steveh5
here's the code I'm attempting to use...
Steve Hilvers
clutsa
Sorry, I'm still lost, what did you think the list should have looked like?
Was it supposed to go to 20 or just bump up to 11?
Was there supposed to be sound with your video that you explained the better?
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
clutsa
Your
MultiValue.SetList
is still inside your "Try" function. Is that why it isn't updating how you think it should?
steveh5
Sorry...there was supposed to be audio, looks like I had mute on.
Will attempt to re-record.
Also, have a call in with reseller to see if they point me in right direction for a several things.
Thanks for the quick replies!!!
Best,
Steve H.
Steve Hilvers
chandra.shekar.g
Autodesk Support
Autodesk Support
@steveh5,
Can you please provide Inventor file to investigate further? please make sure that files are non confidential.
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
