Message 1 of 8
01:24 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I have an assembly which is made with a sub assembly. The sub assembly has iLogic code that both resizes it's parts and suppresses parts that arn't needed after a change in length.
If I open the sub assembly in it's own environment, the rule runs and it assumes the correct size and configuration, based on the parameters passed to it from the top level assembly.
However if I don't open the sub assembly into it's own environment, the parameters are successfully passed on, but the rule doesn't run and the sub assembly stays the wrong length.
I've tried all the kinds of document update I know, but nothing is working.
Hope someone can help 🙂
Cheers
GavoGarmo
