iLogic Sheet Size as External Rule
Jesper_S
Message 1 of 15
Jesper_S
Hi.
Got a Code to change the drawing sheetsize and bordertype.
Planning to run it as an external rule but cant get it to work.
Dim oDoc As Document
oDoc = ThisDoc.Document
Dim Doctype As String = "Drawing"
'doc = ThisApplication.ActiveDocument
'check file type
  If oDoc.DocumentType = kDrawingDocumentObject Then
    Dim selectedSize As String = "Sheet"
    Dim sizeList As New ArrayList
    sizeList.Add("A1")
    sizeList.Add("A2")
    sizeList.Add("A3")
    sizeList.Add("A4")
    'Display input list box and select size
    selectedSize = InputListBox("Select Size", sizeList, selectedSize, Title := "Change size",ListName := "Size")
	If selectedSize = "A1" Then
        ActiveSheet.ChangeSize("A1", MoveBorderItems := True)
        ThisApplication.ActiveDocument.ActiveSheet.Orientation  = kLandscapePageOrientation
        ActiveSheet.Border = "A1"
	Else
	MessageBox.Show("This rule can only be run in a " & DocType & " file", "iLogic")
	Return
The two rows in Red seems to be the problem. If I comment them out it works and i get my Messagebox.
Thanks in advance.
//Jesper
//Jesper
Replies (14)
Message 2 of 15
LishuangLu
Hi Jesper,
The code can be run in my side by changing to an existing border name in the drawing file.
-Lisa
Message 3 of 15
MechMachineMan
Here a transition to using the API instead of iLogic will help.
See enums:
http://help.autodesk.com/view/INVNTOR/2018/ENU/?guid=GUID-55595BC5-77E1-485D-861D-B1FE827EE132
    sizeList.Add("A1")
    sizeList.Add("A2")
    sizeList.Add("A3")
    sizeList.Add("A4")
            oDoc.ActiveSheet.Size = DrawingSheetSizeEnum.kA1DrawingSheetSize
            oDoc.ActiveSheet.Orientation  = kLandscapePageOrientation
            oDoc.ActiveSheet.Border = "A1"
	Else
	Return
Did you find this reply helpful ? If so please use the 'Accept as Solution' or 'Like' button below.
Justin K
Inventor 2018.2.3, Build 227 | Excel 2013+ VBA
ERP/CAD Communication | Custom Scripting
Machine Design | Process Optimization
iLogic/Inventor API: Autodesk Online Help | API Shortcut In Google Chrome | iLogic API Documentation
Vb.Net/VBA Programming: MSDN | Stackoverflow | Excel Object Model
Inventor API/VBA/Vb.Net Learning Resources: Forum Thread
Sample Solutions:Debugging in iLogic ( and Batch PDF Export Sample ) | API HasSaveCopyAs Issues |
BOM Export & Column Reorder | Reorient Skewed Part | Add Internal Profile Dogbones |
Run iLogic From VBA | Batch File Renaming| Continuous Pick/Rename Objects
Local Help: %PUBLIC%\Documents\Autodesk\Inventor 2018\Local Help
Ideas: Dockable/Customizable Property Browser | Section Line API/Thread Feature in Assembly/PartsList API Static Cells | Fourth BOM Type
Message 4 of 15
JaneFan
Hi Jesper,
In iLogic, the const name for enumerator is not acceptable, please use its value instead.
I am seeing the error happens at the line:
Please change it to:
SyntaxEditor Code Snippet
ThisApplication.ActiveDocument.ActiveSheet.Orientation  = 10242
Jane Fan
Inventor/Fusion QA Engineer
Message 5 of 15
LishuangLu
Jane is correct, please follow her suggestion to run in iLogic. I've uncommented the Orientation setting line, thus the code can pass in my side.
-Lisa
Message 6 of 15
Jesper_S
Hi.
I kind of forgot one importent thing. Was in a hurry.
What i was trying to to is if the rule is run in an part or assembly, the rule will show me the messagebox and then exit.
Works fine in a drawing.
Sorry.
//Jesper
Message 7 of 15
JaneFan
Hi Jesper,
Here is the thing:
When you run the rule in part or assembly document, it jumps to the line of MessageBox.Show() directly because the DocumentType is not kDrawingDocumentObject.
When you run the rule in drawing document, it run the codes under this judgement statement:
 So please change the line when you run the code in drawing document, it will work:
Jane Fan
Message 8 of 15
JaneFan
Or to make the code look nicer, we can replace the line with the one like this:
ThisApplication.ActiveDocument.ActiveSheet.Orientation  = PageOrientationTypeEnum.kLandscapePageOrientation
Jane Fan
Message 9 of 15
Jesper_S
Hi.
When i run the ilogic code in a Part, i get this message.
Still the same thing, if i comment out the red line it works.
'check file type
    sizeList.Add("A1")
    sizeList.Add("A2")
    sizeList.Add("A3")
    sizeList.Add("A4")
       ' ActiveSheet.Border = "A1"
	Else
	Return
//Jesper
Message 10 of 15
Jesper_S
Thanks @MechMachineMan.
Tried this code and it works as i want when i a Part or Assembly.
But got this when i run it in a Drawing.
Something to do with this line.
if i comment it out ir works.
//Jesper
Message 11 of 15
MechMachineMan
As mentioned by an earlier commenter, it's because you need to put the enum type in before it.
    sizeList.Add("A1")
    sizeList.Add("A2")
    sizeList.Add("A3")
    sizeList.Add("A4")
		Try
		Catch
			MsgBox("Error Changing Sheet Size!")
		End Try
		'oDoc.ActiveSheet.Border.Delete
		'oDoc.ActiveSheet.TitleBlock.Delete
		Try
			oDoc.ActiveSheet.Orientation  = PageOrientationTypeEnum.kLandscapePageOrientation
		Catch
			MsgBox("Error Changing Sheet Orientation!")
		End Try
		Try
		Catch
			MsgBox("Error Changing Sheet Border!")
		End Try
	Else
	MsgBox("This rule can only be run in a drawing file",, "iLogic")
	Return
Justin K
Message 12 of 15
Jesper_S
Hi.
Missed that, works now.
But i still get an error on the border insert.
Do i have to delete the existing border and then insert the new or is it something else?
Is there an Enum for border also?
//Jesper
//Jesper
Message 13 of 15
MechMachineMan
If your border has prompted entries and you aren't supplying those, that could be an issue.
If your border is a different size than your sheet, that could be an issue.
And I do also think you do have to delete the old border before putting the new one in.
These are all things you can test simply - either by trying to perform the same thing with the UI (generally works), or by tweaking your code/test setup so you know that is the only thing that could be wrong.
Justin K
Message 14 of 15
Jesper_S
No promted entries. Same size. Same thing if i delete the border.
If I insert it manually it works. If I remove oDoc. infront of
 and run the rule in a drawing it works, but then it doesnt work when run in a part.
Think i will skip having this as an external rule and just put the code in the template instead.
//Jesper
Message 15 of 15
I found another thread https://forums.autodesk.com/t5/inventor-customization/ilogic-change-drawing-borders-from-assembly/td...
I declared the variables inside the i kdrawingDocumentObject if statement
    Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
    'reference to the active sheet
    Dim oSheet As Sheet = oDrawDoc.ActiveSheet
    'delete current border on the active sheet
    Dim oBorder As Border = oSheet.Border
And the code for changing the border and sheetsize + orientation
            Try
                oBorder.Delete
                Dim oBorderDef As BorderDefinition = oDrawDoc.BorderDefinitions.Item("A1")
                oSheet.AddBorder(oBorderDef)
            Catch
            End Try
The code now works both in a drawing and in all other filetypes displays "this is not a drawing" and exits
If this is horrible use and mix of code, vb, api etc i don't know. But it works 🙂
// Dupont
