iLogic sheet scale
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello -
I am trying to create a rule to place the drawing scale on each sheet that will be derived from the lowest numbered view on that sheet. My main goal is to be invisible to the user, in other words, to keep the user from needing to do anything regarding this function.
I am running into 2 separate issues.
1. how to identify view names on each sheet.
2. how to extract the number from the view name.
Is there anyone who can help with this? I would be extremely grateful. When I am done, I could even share the code. My intent is to create a different title block for each sheet from 1 to 9. (I am hoping anyone using more than 9 sheets doesn't ever work for us, but I have seen 4 sheets used.) (I am also thinking that 9 is a safe number without being too overdone.) Then to create a custom property and link it to the scale for each title block.
The only other way I can figure out to do this is to ask the user to name the controlling view on each sheet specially, (view3 for sheet3, etc.) and use that name to link to the scale. However, I would really like to make this invisible and not rely on users to "not make mistakes".
Thank you,
SmokyRick
