iLogic - Selection of material-libary
uw
uw
Hello!
I try to create an iLogic-rule (or rather a form) to select materials for Inventor(2019)-parts.
The selection of the material in the active material-libary is working fine - with a mulivalue-textparameter ("iPropMaterial") and following iLogic-Code:
  MultiValue.List("iPropMaterial") = iProperties.Materials
  iProperties.Material=iPropMaterial
Then I can choose the material by selecting it in a  iLogic form with a multivalue list.
No problem so far...
But I have many material-libaries in my project, and - if possible - I want to choose the libary first (on the same form) and then the material itself...
In other words: How can I select material-libaries in iLogic!
I am looking forward to your reply and your help!
Kind regards
Reinhard
clutsa
This appears to be working for me. Material_Lib and Material_Desc are custom Properties.
Dim app As Inventor.Application = ThisApplication
Dim proj As DesignProject = app.DesignProjectManager.ActiveDesignProject
Dim MyLibList As New ArrayList
For Each myLib In proj.MaterialLibraries
	MyLibList.Add(myLib.Name)
Next
MultiValue.List("Material_Lib") = MyLibList
'MessageBox.Show(MyLibList.IndexOf(Material_Lib)+1, "Title")
Dim LibIndex As Long
For Each appLib In app.AssetLibraries
	LibIndex = LibIndex + 1
	If Replace(appLib.DisplayName, " ", "") = Material_Lib Then Exit For
Next
app.ActiveMaterialLibrary = app.AssetLibraries.Item(LibIndex)
MultiValue.List("Material_Desc") = iProperties.Materials
If I've helped you, please help me by supporting this idea.
Mass Override for Each Model State
Custom Glyph Icon for iMates
uw
Hello.
Thank you for your reply, but my problem is not really solved yet...
I created a multi-value text-parameter "Material_Lib"
and a rule with your code (just the part for the choosing of the material-libary):
And then I created a form to choose the "Material_Lib":UW_01.png
And although I have 3 material-libaries in my project (with "favorits" there are 4) I can not select them:
The only libary in the list is the "InventorMaterialLibary", but in my project the language is german, and the Name should be "Inventor-Materialbibliothek"...
I hope somebody can help me!
Regards
 Reinhard
clutsa
Try this...
For Each myLib In app.AssetLibraries
	If myLib.MaterialAssets.Count > 0 Then MyLibList.Add(myLib.DisplayName)
Next
	If appLib.DisplayName = Material_Lib Then Exit For
Next
it only grabs LibraryAssets that have Material Assets... for me Favorites is blank so it doesn't show up.
uw
Hello!
Thank you very, very much!
That was exactly the code I was searching for!
It works perfectly!
Regards
 Reinhard
