ilogic - Select all visible compnents and change appearance, welds to differ one
steveh3
Advisor Advisor
steveh3
Gang...
Somewhat new to ilogic.
Attempting to select all visible components in an assembly and change appearance to a particular color.
Then I want to change the Welds to a different color.
Searched quite a bit and not finding anything.
Any help?
Thanks in advance,
Steve H.
Steve Hilvers
Inventor Certified User / Vault Professional Influencer
JelteDeJong
try this iLogic code:
Dim doc As AssemblyDocument = ThisApplication.ActiveDocument
' set your collors/assets here Dim assetOccurrences As Asset = doc.Assets.Item("Chestnut") Dim assetWelds As Asset = doc.Assets.Item("Brass - Satin") For Each occ As ComponentOccurrence In doc.ComponentDefinition.Occurrences occ.Appearance = assetOccurrences Next Dim weldDef As WeldmentComponentDefinition = doc.ComponentDefinition weldDef.WeldBeadAppearance = assetWelds
Make sure that the assets (colors) are in the part. (if the are only in the AssetLibraries then they need to be copyed to the part)
Jelte de Jong
Blog: hjalte.nl - github.com
steveh3
Thanks Jelte...
Inserted your code recommendation into my logic and getting an error...
'Define current document
Dim odoc As Document
Dim oCompDef As ComponentDefinition
odoc = ThisApplication.ActiveDocument
oCompDef = odoc.ComponentDefinition
Dim oviewrep As DesignViewRepresentation
Try
oCompDef.RepresentationsManager.DesignViewRepresentations.Item("Hi-Lited Welds").Activate
Catch
 oviewrep = oCompDef.RepresentationsManager.DesignViewRepresentations.Add("Hi-Lited Welds")
 'Activate new View Rep
 oViewRep.activate
End Try
Next
'Turn off ALL object visibility
ThisApplication.ActiveDocument.ObjectVisibility.AllWorkfeatures = False
ThisApplication.ActiveDocument.ObjectVisibility.ConstructionSurfaces = False
ThisApplication.ActiveDocument.ObjectVisibility.Sketches = False
ThisApplication.ActiveDocument.ObjectVisibility.Sketches3D = False
ThisApplication.ActiveDocument.ObjectVisibility.SketchDimensions = False
ThisApplication.ActiveDocument.ObjectVisibility.Annotations3D = False
If odoc.DocumentType = kAssemblyDocumentObject Then
  ThisApplication.ActiveDocument.ObjectVisibility.WeldmentSymbols = True
  ThisApplication.ActiveDocument.ObjectVisibility.Welds = True
End If
Think it has something to do with lines that set the colors...but I'm not good enough to decipher.
Again...Thanks so far. Getting closer 🙂
Steve Hilvers
chandra.shekar.g
Autodesk Support
Autodesk Support
@steveh3,
Hoping that suggestions in the below forum discussion may be helpful.
https://forums.autodesk.com/t5/inventor-customization/change-part-color-in-sub-assembly-from-top-ass...
Thanks and regards,
CHANDRA SHEKAR G
Developer Advocate
Autodesk Developer Network
steveh3
Thanks for all the help thus far.
Getting back into this code. I thought I had it running, but getting an error. Have to manually set colors first. After I do that and delete the view rep out...then ilogic will run.
Here's a video showing what is happening....
https://autode.sk/2K6xL00
Best,
Steve Hilvers
Steve Hilvers
steveh3
bump, bump, bump....😁
Steve Hilvers
