ilogic Search and Replace part names
Heey there,
I was wondering if there is a possibility to replace a part of a part name.
For example:
I read the current project number with:
currentproject = Left(iProperties.Value("Project", "Part Number"),5)
 Then i want to replace the number (only the first five digits) in all the ilogic rules.
Parameter("20115-0202-000:1", "test") = test
In the code above i want to replace the number 20115 by the currentproject number(let's say 12345).
I know it's possible to do the search and replace but that's to much work when it's needs to be done everytime that I start a new project. Thats why  I was wondering if its possible to programm this step.
I am looking forward to hear from you!
Greeting from the Netherlands!
Bianca
JhoelForshav
Hi @Anonymous
Are you looking for something like  this?
currentproject = Left(iProperties.Value("Project", "Part Number"), 5)
For Each oRule As iLogicRule In iLogicVb.Automation.Rules(ThisDoc.Document)
	If oRule.Name <> iLogicVb.RuleName
		oRule.Text = oRule.Text.Replace("20115", currentproject)
Next
The rule loops through each rule in the document and replaces "20115" with the string stored in variable currentproject
Dim string1 As String
string1 = CStr(currentproject) + "-0202-000:1"
Parameter(string1 , "test") = test
 I found out that this also works and isn't relliable of the starting number.
For example if i change the project number twice or even more the programm will stil work as it should.
