ILOGIC run rule in IAM then run rule in IDW
what is the procedure for linking ILOGIC rules? There has to be some way, either they are both called from a VBA or VB.NET program.
i want to update parameters in an assembly, then write out the updated IDW to a DWG and/or PDF, then update the parameters, write out etc.
I have both the Rule working in the IAM and the Rule working in the IAM, i just want to call them sequentially.
ugh, typo,
last line, i have the rule working in the IAM and a different rule working in the IDW
Vladimir.Ananyev
One approach was already discussed here
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/Ilogic-runrule-in-idw-from-rule-in-ass...
See iLogic Help on the following functions:
  • RunRule
  • RunExternalRule
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
