Ilogic - run external run from assembly in each newly created idw
Hi
I have an ilogic rule that creates an idw of all files beginning with the same 3 numbers as the assembly.
I want to run another external rule in all of these newly created idw's from within the same rule.
Below is my rule:-
 SyntaxEditor Code Snippet
'Define the open document
Dim oDoc As Document
oDoc = ThisDoc.Document
'Look at all of the files referenced in the open document
Dim docFile As Document
ModelName = IO.Path.GetFileName(ThisDoc.ModelDocument.FullFileName)
'MessageBox.Show(ModelName)
DP= Left(ModelName,3)
'MessageBox.Show(DP)
If Not ThisApplication.ActiveDocument.DocumentType = kAssemblyDocumentObject Then
    Return
End If
For Each docFile In oDoc.AllReferencedDocuments
    Dim FileNameTemp As String = (Left (docFile.DisplayName, 3))
    If FileNameTemp.ToUpper = DP Then
    'open the indexed file
    'true opens the file normaly
    'false opens the file programatically without generating the graphics
    ThisApplication.Documents.Open(docFile.FullFileName, False)
    'zoom to front view all
    iLogicVb.RunExternalRule("Apply front view")
    auto = iLogicVb.Automation
    auto.RunExternalRule(docFile,"Draw all from assembly1")            'run external rule on opened docFile
    'auto.RunExternalRule(docFile,"Draw all - Drawing rules2017")    'run external rule on opened docFile
    'you may also save And close this drawing document
    docFile.Save
    docFile.Close
    End If
Next
iLogicVb.UpdateWhenDone = True
I want to run the rule "Draw all - Drawing rules 2017" in all the new idw's,(commented out) I think is is something to do with "docfile" maybe needs something with "ThisDrawing" in in?
HermJan.Otterman
can't you put an "before save" trigger in you template to run the second extrenal rule?
so when the drawing document is saved, it will execute?
If this answers your question then please select "Accept as Solution"
Kudo's are also appreciated Smiley Wink
Succes on your project, and have a nice day
Herm Jan
Hi
Yes, but I was trying to avoid using event triggers.
JoAntt
Sub Main
' Assembly
	Dim oAsmDoc As AssemblyDocument
	oAsmDoc = ThisApplication.ActiveDocument
' References
	Dim oRefDocs As DocumentsEnumerator
	oRefDocs = oAsmDoc.AllReferencedDocuments
	Dim rdoc as document
	For Each oRefDoc In oRefDocs
		If oRefDoc.DocumentType = Inventor.DocumentTypeEnum.kDrawingDocumentObject Then
			rdoc = ThisApplication.Documents.Open(oRefDoc.FullFileName,True)
			maker(oRefDoc)
			rdoc.Close(True)
		End If
	Next
End Sub
Public Function maker(odocc)
	Dim oDoc as Inventor.Document
	oDoc = odocc
	auto.RunRule(oDoc,"RuleFileName")
End Function
